Question about Sony VAIO Computers & Internet
Lan port my lan port seems to have expanded more than it was initially. is that possible and how do i solve this issue?
    New Friend:
  • 9 Answers
What do you mean expanded?? In physical size?? Get a new network card installed at a local store. There is no way to "shrink" it...
Possibly try a newer cable, perhaps your cable tab is becoming flimsy.
Posted on Jul 29, 2013
How to speed up internet network
The speed of your internet is determined by your service provider and their modem. If possible, connect directly to the modem to check the speed. If you suspect you D-Link router is not allowing you to get full internet speed, first a Hard Reboot of you Router and Modem.
If that did not solve the issue, try a known working LAN 5e cable between your modem and router. After you have established it is not a cable issue, do a factory reset.
I had an issue where my speed to the internet modem was fine, but the router LAN connections only provide a faction of the internet speed. After testing cables, etc I did a factory reset and it restored full connection speed on my router LAN ports.
Feb 27, 2016 | D-Link Computers & Internet
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
INTEL ATOM D945GCLF ( LAN not working)
when you give power to computer press F2 or F1 or "del" key then enter in bios .
Then go to advanced configuration then check your lan port is disable? if it then enable it.
then check.
If it is in warrenty then take it to service shop they repalced it if it has hardware lan chip has issue.
Aug 07, 2009 | Intel Motherboard
Port forwarding not working in ok firmware AGL6 or later
According to my very thorough testing some weeks ago, P-660-HW-D1 port forwarding is really very broken.
The worst thing is that not only does the port forwarding work properly, it lets packets to LAN addresses where they're not supposed to go. This means you're not safe behind LAN.
Firewalled or not, AGL.6 or AGL.7 shouldn't be used at all in my opinion, they're unsafe. When in routing mode, and having several LAN machines behind one Zyxel switch port (i.e. separate switch attached), I found that the port forwarding is completely broken.
I have contacted Zyxel Finland about this issue two weeks ago, and they initially thanked for the finding and said they're passing the issue onwards and investigate it.
The best current solution is to downgrade to (also very buggy) AGL.4.
May 13, 2009 | Zyxel P660HW-D1 Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
How to use cross cable and straight cables in network
ok, i think what you mean is this.  Crossover cable is for connecting 2 computers together without the need for a router.  also called pc-to-pc.  Straight cables need the use of a router or hub to connect 2 computers together.  Hope this helps, if not let me know more info.
Mar 06, 2009 | Southwestern Bell (S60802)
Soundstation2 direct connect ex for nortel
try repalcing the adapter if u have another one.this should solve the problem.if it doesnt , the main board needs repair!!
Jan 15, 2009 | Polycom SOUNDSTATION2 AVAYA 2490...
Lan
If you are referring to the Ethernet cable, initially, it can then be presumed that your computer then has no LAN port. What would be required is purchase and installation of an add-on networking card. Although it is quite rare for most modern desktops not to have a built-in LAN port. The image below is an example of an add-on PCI LAN card
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Linksys Wireless-G Broadband Router
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Computers & Internet Logo
16 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
