Maytag MDB7100AWB Dishwasher Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It runs but nothing gets clean maytag dishwasher
  • 3 more comments
  • j_santini1 Apr 01, 2009
    my maytag dishwasher mdb7100awq goes thru all cycles but nothing gets clean
  • tkcham May 02, 2009
    I have the same problem...food remains on the dishes and I'm finding black specks on everything. Where is the filter located? Mine is a Maytag Jet Clean EQPlus, Model #MDB7130AWW.
  • Anonymous May 13, 2009
    I have the same problem like to have a solution
  • laotramama May 23, 2009
    I have the same problem. Mine is a MDB7100AWB.  Can you be more specific about how to remove the spray arm and how access the filter?
  • Jeff Meyer May 11, 2010
    What is the model number of your Maytag dishwasher?
Jeff Meyer
Level 3:
  • Master 423 Answers
  • Posted on Apr 01, 2009
Jeff Meyer
Master
Level 3:
Answers
423
Questions
5
Helped
287293
Points
1081
With nothing getting clean, the first thing to do is clean the filter and also underneath it. You will need to remove several screws and the lower spray arm to do the cleaning. Watch out for broken glass! Rinse out the filter as best possible.
Look carefully at the impeller to make sure it spins freely and is not damaged. While you are down there, look for any problems (brakes/damage) with the heating element.
Reassemble the filter and spray arm. Test with a load of dishes.
If problems continue, but the spray arms appear to be spinning well, the problem is most likely a failed heating element. Replacing it should make thing work much better.
Please get back to me with what you find. Good Luck!
Maytage dishwasher not running, clean light blinking
the maytag control panels are known to have issues. the problem is they are not sealed properly and over time steam gets in and eventually it shorts. it is fairly easy to change, but you should have it diagnosed by a qualified technician to know for sure. good luck! http://www.searspartsdirect.com/part-number/w10380486/0022/665.html
Oct 04, 2016 • Dishwashers
4helpful
2answers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
1helpful
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
2helpful
Maytag dishwasher
Go buy a product called Lemi-shine and run it thru your dishwasher empty to clean out any hard water and soap deposits. If you can try using only about 2 table spoons of detergent and stay clear of the premeasured tablets. Most of the dishwashers being sold are low water usage units and it is very easy to overwhelm them with soap. It also helps if the oils from the foods are still on the dishes. People tend to clean the dishes to much before loading them and then the enzymes in the detergent have nothing to attach to. Basically this leaves the soap nothing to attach to except the dishes and hence you get cloudy dishes with soap stuck all over them.
Jan 30, 2010 • Dishwashers
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
5helpful
2answers
Clogged filter
Hi, The mesh does not open. You will need to GENTLY clean each section with running water. Are you using powder or liquid soap?
The most common thing that plugs them is food particles. This unit is best served by pre-rinsing the dishes. The mess gets plugged to easily.
I hope this helps.
Vic
Cannot start the dishwasher - no light, no movement whatsoever
Hello, First thing you want to do is check your circuit breakers to see if the one for the dishwasher has tripped. Also look under the sink.. Many dishwashers are plugged in to an outlet under the sink and sometimes the plug can get pulled out. Check these things first and let me know what you find. Good luck.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
