Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 40bv702b led blinking red and green
The lcd blinks but it cant power on
IFIXALL
  • 868 Answers
SOURCE: led light blinking
First try a hard reset. Just unplug the power cord for 4 hours or more; then try again.
If the reset does not help it means the problem is hardware failure and not software. Therefore, you will need a tech who can diagnose the electrical circuits. The short circuit conditions could be in any location within the 8 or 10 sections of the tv.
Please Rate This !!
Posted on Jun 12, 2008
djchillsnyc
  • 152 Answers
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Posted on Dec 18, 2008
  • 5 Answers
SOURCE: Blinking RED power Light 42hp95 Toshiba
I turned the 42HP95 TV off one night and it didn't come back on. Had the red LED flashing etc. Found the solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back but didn't take it seriously because these things never work, others were mocking the answer blah blah. Well, just before kicking the damn thing to the curb, I grabbed a screwdriver, took off the back cover, unplugged the little do-hicky sugested in the Solution, and the idiot box came right back on. Go figure. Been working ever since. SO, you might want to try this before busting out the electrical schematics and dropping $$ on repair. Cheers.
Posted on Feb 20, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: toshiba plasma 42hp95 tv will not turn on red led lights blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Panasonic LCD TH-L32C2OM when I on the above lcd tv green led blinking and within few seconds red led blinking 4 times
Looks like a power supply trouble or capacitors not good. Has to be open and check by a pro. Good luck,
Serge.
Dec 27, 2015 | Panasonic Televison & Video
Green led in ON but red led in blinking,after so many blinks of red led the both lights ,red and green,gone off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 15, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
