Computers & Internet Logo
A
Anonymous Posted on Jul 29, 2013
Acer e415sm processor support
Dali ova maticna moze prihvatiti dual core processor koji je E2200
5 Related Answers
Anonymous
  • 1067 Answers
  • Posted on Jan 20, 2008
SOURCE: compatible
document.write(neg_specification_newline('LGA 775')); LGA 775 CPU Type document.write(neg_specification_newline('Pentium EE / Pentium D / Pentium 4 HT / Celeron D')); Pentium EE / Pentium D / Pentium 4 HT / Celeron D FSB document.write(neg_specification_newline('1066/800MHz')); 1066/800MHz
thats what u can use ok
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 13, 2008
SOURCE: acer boards
this is what your comp can be upgraded to threw these specs i had in my comp book specifacations
hope this helps
Specifications Product
Aspire E560 Language
English Model
Aspire E560 Specifications Specifications
Processor
Intel® Core™ 2 Duo processor up to 2.13GHz with 1066MHz system bus
or Intel® Pentium® D processor up to 3.4 GHz with 800MHz system bus
or Intel® Pentium® 4 processor up to 2.8GHz with 800MHz system bus
Cache
Depending on the CPU
Memory
256MB 400/533/667 DDR2 expandable up to 4GB
BIOS
Flash BIOS
Supported Protocols
PCIX 1.0, PCI 2.2, APM 1.2, VESA/DPMS (VBE/PM V1.1), SMBIOS 2.3,
E-IDE 1.1, ACPI 1.0b, ESCD 1.03, PnP 1.0a, Bootable CD-ROM 1.0,
USB 1.1~USB 2.0, UHCI 1.0, ANSI ATA 3.0, ATAPI
FCC, ETL and NOM certifications v 1.10
System Chipset
ATI RC415 + ATI SB600
johnyu_05
james yu
  • 141 Answers
  • Posted on Jun 26, 2008
SOURCE: graphics card
Hi bob,
Is your onboard video busted? as i check your specs; you have these slots available in your motherboard
2 ( 2 ) x PCI ¦ 1 ( 1 ) x PCI Express x1 ¦ 1 ( 1 ) x PCI Express x16 ¦ 1 ( 0 ) x processor ¦ Memory
base from:
http://www.twenga.co.uk/specs-Aspire-T180-ACER-Desktop-PC-243132
so, you can go to your nearest computer shop and ask them for a videocard that uses PCI Express x16, if its for gaming then go for the higher specs, i can't assist you further with regard to the exact video card model though.
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Oct 01, 2008
SOURCE: Uppgrade of processor!
Either there is a problem with the physical fitting of the processor, or the motherboard is not equipped to handle said processor, even with a bios revision.
Sutibun
Stephen Wilkins
  • 186 Answers
  • Posted on Oct 02, 2008
SOURCE: upgrading my laptop's processor to a lower processor
No laptops graphics are integrated into the motherboard and cannot be change with any bit of ease
1helpful
Nema stand by monitor Acer AL1916
Pozdrav, ako vam se uopste ne pali monitor problem je u napajanju i to kod tog modela je cesta pojava.Najverovatnije je potrebno zameniti elektrolitske kondenzatore. Kompletno uputstvo imate na https://www.youtube.com/watch?v=VgMUpqTBLuA
PAZNJA:Ako niste posebno upoznati sa elektronikom vodite racuna jer moze doci do strujnog udara iako je uredjaj iskljucen.Nadam se da sam vam bar malo pomogao.
Acer AL1716 AL1916W AL2017 AL2416W LCD Computer Video Monitor Repair...
Intel Pentium Dual CPU E2200 @ 2.2GHz
the driver depends on your hardware (chipset on m/b and any cards that you have) and the operating system, not the CPU. Please supply your o/s and hardware information
KAKO DA PROMENIM PASWORD OD WI FI
U browseru ukucaj adresu 192.168.1.1 i uloguj se kao admin, admin. Nadji Wireless opcije i tu ces naci i sifru. Ako ne mozes da udjes u podesavanje rutera, klikni na LAN ili Wifi, pa Support pa Details, i vidi koji je Gateway. Ukucaj tu adresu u browser i trebalo bi da mozes da pristupis ruteru.
Rowa tv code
073,079,075,081,093 are the codes to check. For more http://electrohelponline.blogspot.com/
I ned driver pc desktop acer aspire e2200
Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Dual Core VS Single Core
basically it depends on the Bus speed of the processor. if u r using the single core processor with high bus speed it means u r using faster one then the low bus speed core 2 duo. n the other thing is depends on the system memory (ram), if the Ram is compatible with Processor speed n processor bus speed, ur pc will work faster...
good luck
shafky
ASUS MAKING NOISE
2 things come to mind when I hear this; the case fans or the power supply fans. I would check those first to see if they are the problem.
Intel processor E2200 LGA775 not working
This motherboard supports Intel single core Pentium 4/ Celeron processors, according to the asus website.
So your dual core is not supported.
You need to get a intel pentium 4 or celeron processor
Grand Canyon Tech
Grand Canyon Tech
