I have a digitech XC4881 scanner neg.film/slide. Have installed on Windows 8 but when transferring negatives and slides come out black. Why?
bbd94
  • 4 Answers
SOURCE: cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Posted on Mar 16, 2008
  • 111 Answers
SOURCE: how do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Posted on Jul 09, 2008
old marine
  • 2124 Answers
SOURCE: No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Posted on Sep 30, 2008
SOURCE: My Mom purchased a Jobar's slide & negative scanner by RX Optics
install for scanner for umax astra 2500 for windows 7
Posted on Mar 29, 2010
SOURCE: OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Posted on Feb 06, 2011
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
Digitech xc4881 driver
For what operating system? There are a ton of posts about this on google. If you are using Windows 7 then use the vista driver as administrator and in compatability mode.
May 22, 2014 | Microsoft Windows XP Professional
Digitech XC4881 - cannot scan colour negatives under Windows Vista. OK with XP.
if you right click on the shortcut/exe and go to properties, there should be an option to run in compatibility mode and run it as XP.
Mar 10, 2011 | Computers & Internet
I Have Just bought a digitech xc4881.new pc with windows 7 64bit
That is it. Scanners are notorious for needing another driver when you use 64 bit OS.
Sep 16, 2017 | Office Equipment & Supplies
Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Jan 25, 2009 | Canon CanoScan 4400F Flatbed Scanner
Unable to scan b/w neg's correctly using Digital ICE
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Jan 16, 2009 | Nikon CoolScan V ED Film Scanner
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
48 people viewed this question
k24674
jasbo
jasbo
