Compaq presario v5000 laptop
WHEN I LOGIN MY LAPTOP ITS TOO SLOW AND THE MESSAGE IS COMING SMART FAILURE PREDICTED ON HARD DISK 0"ST94813AS-(S1) WARNING IMMEDIATELY BACK UP YOUR DATA ND REPLACE YOUR HARD DISK DRIVE. IF FAILURE MAY BE INENT PRESS F1 TO CONTINUE
    Problem Solver:
  • 16 Answers
Do what it says and backup immediately.
  1. After everything is backed up, download and run Speedfan.
  2. then open "S.M.A.R.T" data for your drive and click "Perform an in-depth online analysis of this hard disk"
3. I will send the diagnostic data(it is safe as does not contain any private info) to a hddstatus.com webpage and open analysis result.
4. Paste the permalink from results page here. It is on the bottom of page and reads "this".
Then we could see what exactly is about to fail but most likely you will need a new drive(SSD prefered) or a new laptop. Depending on laptop specification replacing HDD with SSD drive could inject a new life in this rather old laptop.
Posted on Jul 29, 2013
2 Suggested Answers
SOURCE: SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
SMART failure error means your hard drive is dying and there is no way to make it working for a longer period of time.
Soon, your hard drive will fail permanently and won't give second chance to work and so prevents you to access any of your important data.
So, before disaster strikes, you're highly recommended to backup and replace your hard drive as soon as you can. Otherwise, you might be in big trouble.
Hope it helps!!
Posted on Jan 08, 2013
Smart failure predicted on hard disk 0:SAMSUNG HM321HI-S1 lik message coming when i on the system.. so wat wat to do now?
Save all of your files to an external storage device (Flash Stick or desktop drive) and the replace the hard drive. Do it quickly, because there is no time period given before it fails. And it will.
Jun 24, 2012 | Dell Computers & Internet
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
How can i fix my acer 5515 smart failure predicted on hard disk 4 wdc wd1600bevt-22zcto-s1
This error message is warning that the hard disk could fail soon. It pays to back up your data frequently so when the hard disk fails you will not lose youe data.
The only way to fix this problem is to install a new hard disk, install Windows on the new hard disk and the Acer laptop's device drivers plus your programs and data.
Feb 18, 2012 | Acer Computers & Internet
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:
http://en.wikipedia.org/wiki/Self-Monitoring,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Dec 31, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
