Question about Whirlpool Dishwashers
Whirlpool adp 252
Burning plastic smell after about 5 minutes
5 Suggested Answers
  • 7 Answers
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Posted on Aug 11, 2009
SOURCE: Whirlpool dishwasher heating element overheating
Same thing just happened to my yesterday on my Kenmore. Expert help needed.
Posted on Dec 04, 2009
  • 291 Answers
SOURCE: code f7 appearing on whirlpool
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck, Appliance Specialists
Posted on Dec 08, 2010
  • 196 Answers
SOURCE: Whirlpool Dishwasher ADP 252 model
Sounds like you have a heating problem. Machines with a timer are controlled by the thermostat, so it wont click on until the machine reaches the correct temperature. Is the water hot? If yes then you need to replace the thermostat and high limit stat. If not hen it will be either the stats or element. Most likely the stats.
  • 2q==
They typically look something like this, but if you visit an online spares site and select your make and model it will give you a breakdown of all the parts. To change put machine on its side and remove the bottom panel, this will give access to the components. If not then tilt machine back and remove the front kicker plate and the the panel in behind. The stats will be at the front of the appliance for access. Hope this helps
Posted on Mar 14, 2011
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Dryer smells like it's burning
You probably have lint build up in the lint houing, you need to clean dryer by take dryer apart ,you may need to call services tech.
Feb 18, 2015 | Whirlpool Dryers
How does the whirlpool adp 252 function?
http://www.manualsdrive.com/captching.php?lang=en&search=WHIRLPOOL+DISHWASHER+ADP+252+VIEW+USERS+GUIDE#.U2zBnVf1WIw
May 09, 2014 | Dishwashers
Noticed burning kind of smell when I put the car in the garage
Could have run over something plastic or you have an oil leak near the exhaust.
Could also be something with one of the brakes.
Can you find out where the smell is coming from ?
Aug 20, 2012 | 2004 Mazda 6
Burning smell from sym orbit II Burning smell after 10 km * + Add a Comment 1. * By avatarChris mcwilliam 5 hours ago * plastic or rubber - something very mu
Hi, Chris the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Jun 27, 2017 | Motorcycles
Our dishwasher started smelling like something is burning, I turned it off straight away, no visible smoke or anything but it hasn't been cleaning very well for a while now. Are these the death throes? Or...
Make sure there isn't any plastic on the heating element. Also check to see if there is any evidence of previously melted plastic. If it smells like plastic burning & you aren't using any heated options, cut the power & call for service.
Mar 27, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Mar 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
Dishwashers Logo
20 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
