Question about Tally T6212 Matrix Printer
Reset tally t6212 - Tally T6212 Matrix Printer
Tally T6212 paper motion fault. Replaced top tractor with paper motion sensor. Found motor not turning at all. Replaced paper motor and power distribution board but its still not turning motor and not...
Did you check the different voltages coming (or should come) out of the power supply?
When a display works, will not implicate the power supply is working correct. It is too long ago I worked with these kind of printers, but I don't think the stepper motors need a capacitor. The caps can be defect, and can cause the loss of one or more output voltages.
Jul 09, 2014 | Office Equipment & Supplies
My T6212 crashed. I replaced the hard drive with a new one but the installation process for Windows XP (and Ubuntu) starts but then hangs. Any ideas what could be causing this? Thank you for your help...
If you have multiple memory sticks(RAM), try using only 1 memory stick(at least 246MB of RAM) for the installation. It could be the memory causing the problem.
Hope this helps! :D
Sep 08, 2010 | E-Machines T6212 PC Desktop
How do I remove the front tower panel to access the power button for replacement in my emachines T6212? Thanks!
Most front panels are held on by friction plugs that have a spring like function that expands into the hole. Gently pull on one end of the front panel and it comes off.
Aug 21, 2010 | E-Machines T6212 PC Desktop
I have lost my tally password.how can i
boot from PE cd and reset ur password
Apr 05, 2010 | Tally LA650 Matrix Printer
Can an eMachines T6212 be upgraded with an Athlon 64 FX60 CPU?
it cannot be done if you want to use the same motherboard
Mar 27, 2010 | eMachines T6211 PC Desktop
What type of motherboard i have on emachines t6212 with a ati pci express slot is it a 2.0 or 1.1 have a64 bit amd porcessor
emachines t6212 uses the ATI Radeon Xpress 200 chipset which is Compliant with the PCI Express 1.0a Specifications
Oct 05, 2009 | E-Machines Computers & Internet
How do i restore/recover my t6212 back to factory installed software?
Do you have a recovery CD? If so, just boot from that cd.
Apr 11, 2009 | E-Machines T6212 PC Desktop
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally T6212 Matrix Printer Logo
22 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
