Question about Samsung SGH t340G Straight Talk Cellular Phone
Have full bars on signal but the no service signal pops up at the same time what could cause this? how do i fix it?
    Problem Solver:
  • 8 Answers
How old is your phone? Mine has been doing the same thing. I turn it off and then back on and it's fine, but there is obviously something wrong. It started right when my phone turned about 2 years old, so I kind of figured it had to do with the age. Does it work for you to turn off and back on?
Posted on Jul 29, 2013
How to fix my celphone
Hi Maria
This is a problem that your mobile carrier can answer correctly. However, since you have posted your question on Fixya, I will provide some tips for you to check on.
Some possible causes on your communication problem:
1. "NOT REGISTERED TO NETWORK"
This message will appear for the following reasons - Network signal is weak - somewhere on the top of your display is a triangular shape with bars. Signal strength is displayed here. If you see only a few bars highlighted, and changes randomly, this is an indication that problem is with the signal.
Other times the problem may be with the phone. When the SIM card is not properly seated in its housing, phone will go off - on -off - on, at a slight touch.
Another possible cause is a partially dislodgement of the internal connections/ joints of the phone's antenna. If your phone was subjected to a hard knock, this will cause a similar problem.
Check those and if you cant resolve your problem, contact you mobile carrier for assistance.
Sep 22, 2014 | Cell Phones
91 F150 turn signal diagram
Here's the schematic for an 88. Your 91 used the same turn signal/hazard switch.
Note if you purchase another turn signal/hazard switch there are two types.
One is for a tilt wheel and the other is for a non tilt steering wheel.
Next picture shows the connector pin out of the turn signal/hazard switch and
how to test the switch.
Sep 20, 2012 | 1991 Ford F150
2002 Chevy Trail Blazer. Loud pop sometimes in rear when turning. Noticed sway bar is loose, bushings worn out . Could that make the pop noise or is problem possibl worse?
sway bar bushing could be problem. I would replace it before trying anything else and yes that will cause it to pop from time to time. In some cases if not replaced in time the bar itself could break
Aug 12, 2012 | 2006 Chevrolet Trailblazer
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
Low or no signal. on tmobile g1 . Even when next another g1 with full 5 bars of signal my g1 will have only one or no bars of signal. Can this be fixed or Can I boost signal?
yes take the screws off including the one on the warranty void, and disconnect the cables and connect back, thats wat i did to mines and is all good now,,
Oct 14, 2009 | HTC G1 Smartphone
LG KS360 Signal in and out and roaming all the time
Mine does the same thing. But that actually is because my house has terrible signal in certain parts... The best thing to do is to make sure that where you do makes call ect. is somewhere with very good reception..
Something like that tho can't really be helped.. I think this phone is just generally terrible for getting a good signal.
Jun 16, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Sometimes my K550i will hang-up it takes minuet back to normal. Also my K550i have problem in sending message even if has a full bar signal. What is the best solution to fix this
If the external memory card is too much loaded , this happens.or if there is too much application running , this may happen . so delete some large application and run one application at a time. Pertaining to messaging , that would have happened due to tower problem .... if it happens continously , then the tower detecting signal sensor would have been faltered . go to service centre with ur mobile and get it rectified
Feb 21, 2009 | Sony Ericsson K550i Cellular Phone
Computer problem
virus protectors are like things in ancient world now days its spyware virus scanners lost there credibility to spyware programs cause spyware is quicker faster and they hide better but not from proper proggies
you need a strong firewall program like zone alarm
and spyware programs like spywareblaster and spy bot these programs are free bee's not shareware full functioning programs
you need to upgrade service pack 2 and internet explorer 7 with built in pop up blocker
wacovia pop ups are a phishing program looking to destroy comps these are spy ware and trojans hiding ready to strike once you get the recommended programs up these spy's should disapear
May 08, 2008 | Acer Aspire 5100 Notebook
Poor signal strength
have a go at changing the wireless channel within your router there may be some interfearence generated by your pc that is affecting its signal strength
Oct 29, 2007 | Computers & Internet
Samsung SGH t340G Straight Talk Cellular Phone Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
