Question about Garden
Stripping down a Flymo HTC24 hedge trimmer
How do you strip down a Flymo HTC24 ( a 24volt portable hedge trimmer)? I have removed all screws from the handle but the locking ring to extend the reach seems to be holding the top half of the handle.
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
  • 64 Answers
SOURCE: I have lost the screws out of the hedge trimmer attachment
go to the hardware store and find screws that fit properly
Posted on Jul 11, 2009
eugbug
  • 479 Answers
SOURCE: THe engine has seized on
You could try removing the spark plug and spray WD40 into the cylinder and leave it for a day. Remove the starter assembly first though and check whether this is somehow preventing the engine from turning.
Posted on May 13, 2011
ianharper74
  • 5 Answers
SOURCE: flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Posted on Sep 09, 2011
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Neuton cordless hedge trimmer sounds "rattly" and the blade doesn't go back and forth. the battery is good. could it be the motor?
Sounds like a problem I had, and it was the primary gear on the motor was stripped. So far no luck at finding the gear, but to replace the trimmer without battery would probably be cheaper.
Feb 19, 2012 | Nike Neuton CE 52 14Inch 24Volt Cordless...
HOW DO YOU REMOVE THE COVERS, THAT ENCOSE THE MOTOR ETC., FROM A FLYMO EASICUT 510? . I HAVE REMOVED ALL THE SCREWS BUT THE COVERS WILL NOT COME APART. HELP PLEASE.
Have you removed the screws that hold the clear hand guard on.? They should just pop apart once all the screws are out.
Jun 22, 2011 | Husqvarna Garden
THe engine has seized on my Homelite hege trimmer. I s there an easy way to free it up without stripping the engine down?
May 05, 2011 | Homelite Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
Jul 23, 2010 | Garden
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Intimitant Fault
Hi !
I can help you with the manual!
http://www.flymo.co.uk/node789.aspx
Go to that site, in the window obove the "search" type HT450
Now you will see all avalible manuals for your hedge trimmer, and there are a couple of them. The manuals are in PDF so you can either download them or read them on your screen
Good luck¨
Nci
Apr 22, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
