Question about LG Televison & Video
Lg dv450 loc
My dvd lg dv450 cant open the cd tray. When i try to open it displys LOC. Any one who knows how i can remove this loc? thanks in advance
SOURCE: Digital Apex dvd/cd/mp3 player tray won't open
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
Posted on Feb 26, 2008
SOURCE: DVD displys "loading" constantly
I have the same unit with the same problem. Its been to JVC 2 times for power supply repair(the power supply overheats). I am now having this again and will send it a third time. I was told by JVC they will replace the unit after 3 repairs. We'll see??
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: LG RH299H HDD/DVD does not read purchased DVD's
To unlock the region limitation of your machine:
(all the following is done on the remote)
Press <Home>
Go to the Easy Setup Menu
Go to <Setup>
"Hover" the cursor block over the Lock symbol (don't enter yet)
Enter 0000 on the remote
A Congratulations message comes up.
Press <Enter>
Posted on Jan 10, 2009
SOURCE: Radio and CD System in LOC mode.
there is a 4 digit security code that is entered by using the hr. and min. buttons. I think the code has to be gotten from GM with the vec. I.D. number.
Posted on Jan 11, 2009
Testimonial: "I found a elligle access on line and got the code I needed. Thanks. "
  • 31 Answers
SOURCE: whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Posted on Feb 07, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My lg dvd player displayes loc
is it displaying loc which means locked? sometimes you have to go thru your remote and set it for dvd and make sure its not on tv
Mar 11, 2014 | Samsung DVD-V4600 DVD Player/VCR
The buttons on my Lg bd550 dvd player dont work
If a disc in the unit it may have jammed something in the mechanism---someone would have to open and visually inspect the loading mechanism first.
Oct 16, 2012 | LG BD550 Blu-Ray Player
Reginal code for model dv450
Hello Guin,
The region code hack for DV454 works perfectly on LG DV450:
1: Press "Open" button on the player
2: Press "pause" button on the remote
3: Press "3" "1" "4" "1" "5" "9" button on the remote
4: You can check on the TV screen as now you can set your region code.
5. Press "0" button on the remote to select "Multiregion".
6. Press "pause" button on the remote.
7. Swith Off the player and wait for a few sec.
8. Swith On the player and it works.
Oct 18, 2011 | LG Televison & Video
My Sony DVP-NS55P tray to put the CD is locked and can't open it and I can't locate manual.
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPNS55P&LOC=3
Sep 05, 2010 | Sony DVP-NS55P DVD Player
I have Service & repair manual on dvd that doesn't load when put into the pc dvd drive
try another cd in the drive if it work perfect try clean the actual cd and sceck for scrates and keep trying if need this is the page support of your product thanks ( http://esupport.sony.com/US/perl/model-home.pl?mdl=PCVRZ30C&LOC=3 )
Nov 07, 2009 | Sony VAIO RZ30C (PCVRZ30C) PC Desktop
Lock nut problem
sears sells a nut removal for wheel nuts as you turn the socket it bites into the nut to remove it there are different sizes in the kit .
Dec 15, 2008 | 2004 Honda Accord
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Televison & Video Logo
Computer Repairing
Computer Repairing
