How do you strip down a Flymo HTC24 ( a 24volt portable hedge trimmer)? I have removed all screws from the handle but the locking ring to extend the reach seems to be holding the top half of the handle.
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
SOURCE: removing inside door handle
i have a hyundai accent 2001 and i need to find fm stations manually.
SOURCE: oven door handle falls off screw not holding on Kenmore 790.7876
After several unhelpful calls, we called sears parts at 1800-366-7278 and they are sending us a supposedly 'new and improved' door handle & screws (for $44). When we receive it, we'll put up a post if it is actually 'better' or if it's just the same (to save others the same $44 charge). The part comes with a 90 day guarantee. Although I don't feel we should have to pay $44 to solve an obvious manufacturer flaw - we'll just be happy to have an oven that's 'safe' to use again. Fingers crossed.
SOURCE: flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
