Vaio vpcs11x9e my sony vaio vpcs11x9e flashes green light for a long time before boot after i pressed de power button
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
  • 107 Answers
SOURCE: sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Posted on Jan 25, 2009
  • 38 Answers
SOURCE: Sony Vaio VGN-N250E/W Not Booting/Responding
Take the battery and power supply out and hold down the power button for 30 seconds. This will reset your hardware settings. Your backup battery isnt your problem. Does your battery light turn on when charging? Does your keyboard lights light up when it runs for a second (try pressing caps lock)?
Posted on Mar 25, 2009
thegoshem
  • 61 Answers
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Posted on May 06, 2009
CompuFirm
  • 89 Answers
SOURCE: Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
Posted on May 27, 2009
Sony vaio wont start up
Check it on external monitor first. Plug vga or hdmi cable and power your laptop up. P.S. you might need to press and hold FN key and press F7 to alter between monitors.
Sep 01, 2014 | Sony VAIO VGNSZ Series VGNSZ38GPC...
Sony Vaio will not power on with hard drive connected
I'd say it's time to do a close inspection of the hard drive connector/adapter, especially if it has any components mounted on it. If you can't see a problem you can fix like a short between two terminals, and you can't get another one, get an external USB drive (preferably the largest flash memory stick you can obtain) and set it up as a Linux bootable volume and use that to run your computer. You will probably have to set the BIOS to boot from a USB volume first.
Jan 07, 2014 | Sony Vaio Pcg-R505Tek...
Sony Vaio E series laptop not turning on
check your ram slot.check your bios setup.or reset it.remove your battery press power button 3/5mnt and connect ac power now power on.
May 30, 2013 | Sony VAIO EB Series White Notebook...
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
Power button pressed, doesn't boot
Try taking memory module out and then put it back in, or try using another memory module.
Nov 11, 2009 | Sony VAIO SR Series Notebook PC...
Unplug the tower
May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Mar 25, 2009 | Sony VAIO VGN-N250E/B Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
