Question about Toys
How the actual hand as well as attaching 3 tangles for three wants?
    Problem Solver:
  • 18 Answers
Some time pertaining to cosplay celebration is arriving when Black Retainer Two is present to us. It's a tiny shame that I didn't gown your Dark-colored Retainer cosplay outfits to visit the actual get together last week, because I 'm also occupied to produce a cosplay outfit. A career is really a career. I've no clue about the restricted occasion.
Posted on Jul 30, 2013
Picture shows 3 colors on everything.example.if there's a hand.there's 3 hands and each is a different color Blue .red.green
There are actually 3 projectors inside, each handling one of those three colors which, together, make all the other colors. This is called "out of register" where they are aiming slightly differently. These need to be adjusted.
Jul 31, 2014 | Televison & Video
TANGLED POOL HOSES
Tangling is sometimes problematic with the cleaners. If any of the hoses have gotten stiff it is time to replace them. If the hoses are still soft and pliable, you may need to add more swivels to the hose. This helps a lot, and make sure there is a swivel within 3 feet of the cleaner itself.
Aug 13, 2013 | Pentair White/Gray Legend Platinum...
Stuck drain cable
Yes, any cable can be untangled. There are three vent holes in the drum big enough to get your hand into. Start pulling the twisted section out of one of the vent holes closest to the problem, un-twist it and pull it out the front of the drum where you feed the cable in and out. It may take a little time, but they can all be un-tangled. After you've removed the cable from the drum, you should be able to remove the kink with must your hands in order to straighten out the cable. These drain cleaners come with a 3.8" cable and are fairly easy to un-kink.
Jun 17, 2013 | Ridge Tool Company Ridgid K-400 Drum...
My Bali blinds aren't going up and down smoothly. Actually they only go up a bit then stop.
Take them down and there are three components in the headrail. The string is not wound on the spindle properly and is tangling. You have to get all three to come up evenly.
Oct 07, 2012 | Furniture
My polaris hose keeps getting tangle.
If you have stored your automatic pool cleaner with the hose coiled, this is probably what is causing the problem. Lay the hose out flat and stretch it slightly. Let it sit in the sun for several hours and it should help to straighten in. You should also not store your cleaner with the hose coiled. If you are talking about your sweep hose getting tangled, you might need to adjust it, lower your RPM, or add sweep hose weights.
Nov 13, 2010 | Polaris 3900 Sport Pool Cleaner ()
No My polaris hose keeps getting tangled up, how do I fix it.
Remeasure the pool cleaners hose to verify that it is adjusted to the proper length for the pool shape. With the Polaris operating, check that the swivels in the hose and the hose connections turn freely. Make sure feed hose is floating.With the Polaris turned off, spin each of the wheels. All wheels should turn together.
Nov 13, 2010 | Polaris 280 Black Max Pool Cleaner with...
Pool cleaner tubing tangles on itself.
Check the cleaner feed hose length. It should be just long enough to reach the farthest part of the pool. If it is longer it may need to be cut down. Also look inside the fitting that connects the feed hose to the pool wall. There should be a small metal screen. It may have to be cleaned out to allow proper water flow. If the screen is missing then the jets inside the pool cleaner could be clogged. Make sure the feed hose floats are spaced evenly or arranged so that the hose is floating at the surface. Also there are jets on the back of the cleaner that can be adjusted that may help it pull loops out. One other thing is the head float that is at the top of the cleaner next to the debris bag. Make sure it doesnt have water inside of it. If it does have water in it then replace it.
Aug 01, 2010 | Pentair White/Gray Legend Platinum...
My legend pool cleaner that I bought about 10 years ago is constantly getting tangled up on it's hose. Any solutions?
I would try to have one part on your hand so when the hose try's to get tangled to can controlled the hose where it goes.
May 19, 2010 | Pentair White/Gray Legend Platinum...
Bunching thread underneath
When your thread is bunching at the bottom, your top tension is not tight enough, or you did not thread the machine correctly. Make sure the thread goes through the tension blades. Check your manual how to do it properly. you can check if there is any tension by pulling on the thread before threading through the eye of the the needle, and with the presser foot down. By pulling with the left hand and adjusting the tension with the right hand you should be able to feel a difference. Normal setting is between 3 and 5
Oct 12, 2007 | Singer Featherweight II 117
Toys Logo
73 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
