Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf1432w drum is not moving properly, how do I get to the drum to see if anything is caught
3 Suggested Answers
  • 62 Answers
SOURCE: zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Posted on Oct 20, 2008
57 varieties
  • 1653 Answers
SOURCE: my zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Posted on Oct 12, 2009
Why is the drum on my machine isn't moving?
check ur drum belt or the wheel pulleys and in some cases the center bearing and shaft? my suspicions lie with the pulleys fairly inexpensive and not to hard to replace
Jul 25, 2014 | Zanussi ZWF1230W Front Load Washer
My Zanussi TCE7124W is not running cycles properly and the clothes are still wet at the end of a run
The filters are clogged.
• The condenser is clogged.
• The water reservoir is full.
• The selected cycle is not suitable for the laundry.
• Insufficient drying time.
• The laundry has not been spun properly.
• The low-temperature function selected.
• Excessive laundry load.
• The dryer is not correctly installed.
Also, check the heater elements.
For the movement, check the drive belt has become worn or snapped. To test your tumble dryer's drive belt, we recommend you manually spin the drum. If it is stiff and difficult to move, the drive belt is ok, if it is easy to move, there's a good chance the drive belt is the fault.
Nov 02, 2017 | Zanussi Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
I have a zanussi washer dryer ZWD 14270w and the dryer is taking hours and hours to dry anything..help!
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
Oct 24, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
My zanussi zwf1432w washing machine the rubber
Thats algae, you need to replace the rubber.
Feb 15, 2010 | Washing Machines
Bearings hve gone and washer is just 3 years old is it worth having them fixed or should i get a new washer costing under £200 its a zanussi zwf1432w
Replacing drum bearings is very costly, average cost around £130 so you would do better to replace it.
Jul 29, 2009 | Washing Machines
Zanussi zwf 1020w drum not revolving
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
ZWF1432W Zanussi Washing Machine
has the transit brackets been removed, these are bolts that secure the drum while its being moved, failing that this could be a call out under guarantee, the bolts and location of where they are etc are in the instruction leaflet and differ from machine to machine etc
Oct 03, 2007 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
14 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
