I have a Dish Network 510 DVR Receiver and I know it has an internal Hard Drive. I have recorded shows and I want to transfer those to my computer. Reason I want to do so is because lately updates have wiped out my programs, even the protected ones. I will upgrade soon and I own my DVR so voiding the warranty is no problem for me. Also do you know if the movies are compatible or are they in a different format?I am pretty sure the format is Mpeg4.
Rank: Guru
DISH Network Staff
Rating: 89%, 217 votes
ArmyMason,
Unfortunately as a Dish Network Employee I must inform you that acording to Dish that is not possible however a good computer tech may be able to help you with a work around but keep in mind that if any damage occurs to the receiver that Dish will charge you for the receiver. When you do upgrade check into the receiver models that have an expansion port for an external hard drive. A 211 which is a solo hidefinition receiver without DVR can have a port activated for as one time charge of 39.99 and you can use the hard drive you supply as the DVR. Yoiu also will not be accessed the 5.98 DVR fee every month and if the receiver needs replacing you still have your recordings. Thanks for using Fix Ya.
i have an thomson freeview box dti6300 & it as a usb port on the front at the side of the...
(More)
i have an thomson freeview box dti6300 & it as a usb port on the front at the side of the top-up card. can i send the video footage to the computer.
We have a philco tv, its a PIP, modle # P8348C AK02. We need to over ride the parental controls, we...
(More)
We have a philco tv, its a PIP, modle # P8348C AK02. We need to over ride the parental controls, we got it second hand an for some reason channel 4 is locked out. We do not have the remote for it either! Help Sandyb
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube...
(More)
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube with the standard DVR receiver. Tech says it is an electrical problem. Have tried all troubleshooting suggestions.what do you think? also having some audio issued with the HD tv in living room. tech says that is also electrical
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs....
(More)
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs. and allowing it to reboot. I do this routinely (Once a mo), but did it again. This time it cleared ALL recorded items (including protected items) I had 43 hours available for recording. It also Cleared all scheduled timers, and now will not allow me to record if I try to use "Create A timer" or "Create a Scedule". Is my harddrive fried?? (I've had problems with it locking up for about the last 12 months) Dish Network DVR
