Question about Canon Pixma MP500 All-In-One InkJet Printer
U071 more than one ink tank error ....... help!!!
Hi ive got a canon mp500 printer and im having a problem now ive changed offices. all my ink is new and all original canon and the correct numbers, but it says "more than one ink tank of the following colour is installed" and the screen points to the smaller black cartridge. but it needs 2 blacks anyhow a 8 and a 5. so im scratching my head whilst using my old crappy epson. please help, james. p.s - i dont have an instruction book sadly so if i need to press any buttons etc please be gentle with me and indicate where/what colour or shape the button is your references please - sorry for being lame! thanks
  • 2 more comments
  • do8erman Sep 19, 2007
    thanks to everyone who has made effort here to help me out, ive tried the lot and after a rigerous cleanse exercise and turning on/off etc i think i'll now take the risk of ordering a whole new set of canon carts - if that doesnt work im taking it in the back garden and giving it a damn good kicking, then going to buy an new epson which i should have done originally!
  • Anonymous Apr 17, 2008
    every time i try to print something an error message saying "more than one
    ink tank in the following color is installed (magenta ) On the printer it reads Check ink 0071 which I do and one cartridge is always blinking, not allowing me to print anything. This machine hasn't been used a lot and should not be having these problems.
    karen
  • moeinv Jul 17, 2008
    my canon MP830 has had this problem for a while. At first I just
    reinserted the offending cartridges, which might or might not work,
    Now nothing is working.
  • Anonymous Jan 24, 2009
    I'm having the same problem and the worst part id it's a new ink. It worked when I first installed it, but noe its not reading at all. I'm gonna turn it off for a couple of days and wait for a reply.
  • 3 Answers
I think I have come up with a solution!
When the error happens:
Open the cover and re-seat the cartridge.
Tilt the whole printer forward about 30 degrees or more
Close the cover.
This has worked for me multiple times now. I think there is a small sensor behind the contact chip that detects ink levels and when my printer is flat the level of ink is lower than the sensor, when I tilt the printer the error vanishes because the ink covers the sensor. Though I am not sure why the software in the printer determines that there are duplicate cartridges instead of just a low ink warning.
If you still can't get it try taking a standard pencil eraser and gently rub it over the contacts to clean off any oxidation, also do this to the prongs that contact the chip that are inside the cartridge carrier, They bend easily so do it very lightly.
Posted on Jun 28, 2008
  • JC Cote Jul 24, 2011
    You are a genius! It worked on the second try after I reset the power still in a tilted position. Many Thanks
The problem occurs so regularly that it is clear that there can only be one reason for it:
1. the Canon cartridges work fine for some weeks (1-6!) and then begin to give these error warnings fairly randomly from the point at which they fail;
2. they give the same kind of error warnings - as reported here - through a range of Canon printers;
3. cleaning contacts on the cartridges, or any other cleaning of the contacts in the holder (which admittedly are smeared with ink), makes no difference as the error reports repeat in various randomised forms as reported on these pages and others!;
4. re-installing drivers etc. makes absolutely no difference;
5. the only ‘cure’ is to replace with original cartridges which solves the problem regularly - although some unlucky soul might just get yet another faulty cartridge(s);
6. the ‘good’ chips on these proven cartridges can then even be re-used on non-Canon cartridges;
Sorry - but having tried each and every other logical path it is clear that Canon cartridge failure is the only cause and we should all be writing to the manufacturer and demanding suitable compensation expenses and our time (at least 5-6 hours in my case!) - this is why I have taken the time to list this so you can all cut and paste and send it off with a suitable (polite, I hope) comment.
It has to be said that, cartridges apart, my Canon Pixma MP-830 is brilliant and lives up to the reviews which I read (without a hint of this particular problem!) before buying.
Posted on Nov 23, 2007
On other sites I've seen that this is a faulty chip in the cartridge. With a new one, it should work. Further, canon will apparently reimburse you for the cartridge.
Finally, I had the same problem, and found that opening and closing, taking out the cartridges, and putting them back in often worked ... for a while. Pretty damn annoying. In retrospect, I wish I'd bought a 730, which doesn't have chips -- fewer problems, and you can use cheaper imitations.
Posted on Nov 13, 2007
    New Friend:
I just cleaned the metal contacts on the cartridge and the prongs inside the printer and it works now.
Posted on Jun 03, 2013
Amazingly, I cleaned the gold contacts on both my IP6700D cartridge holder and the cartridge with nail varnish remover on a cotton tip, wiped them with the dry end, re-inserted the offending cartridge and hey presto - unbelievable - the contacts didn't even appear dirty so it may be some wax or grease or something. I didn't even need to turn it off and on - it just worked!!!
Posted on Sep 22, 2009
I'm having this problem too.With my cannon iP6700D as others have said it appears to be a cartridge problem and cannon will reimburse under.I'm sick of printer problems :-(
Posted on Jul 10, 2008
  • Jeff Stanley
    Jeff Stanley Dec 18, 2015
    This was happening to me also with a refilled cartridge. Even though I have a chip resetter, it still happened. In frustration, I turned the printer off. I then depressed the reset button and holding it down, depressed the on/off button. It worked. Just for the heck of it, I tilted the printer forward while it was off to make sure the sensors were covered in ink. However, since the cartridge was full to the brim, I don't see how that could have mattered. Good luck.
  • 4 Answers
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Posted on Dec 05, 2007
I get the same error on my ip6700d, I just lift the cover for a sec and put it down and it prints.
-Chris
Posted on Oct 26, 2007
Check out canon's website for more details...you can download manuals for their products I think there might have been a bad batch of ink cartridges recently. I ran out of black on my MP F20 all-in-one, installed a new one (always buy Canon cartridges) and all of a sudden my print head wasn't registering. I had to order the part, and when I installed it I was still having problems. Once I finally started to get ink going, it said the cartridge was empty already! Bought a new one today and after much fiddling finally got it printing but I still am not getting any blue out of the color cartridge (also a brand new cartridge). Oh well, I print 99 percent black anyways.
Posted on Sep 16, 2007
Take out all of the cartriges and the take out the container that holds them. Inside the container in the back are circle color index clean the index with que tips (does not have to be completely clean)install all cartriges and restart printer.
Posted on Sep 04, 2007
I just turn off my Canon Pixma IP6700D printer from power and after turning on problem disappear.
Posted on Sep 19, 2007
I have an error on my canon pixma mp500... it says The type of printhead is incorrect. Install the correct print head. I bought some ink that says that it is compatible for my printer and when I tried it...
i would like to suggest that u should not use any alternate cartridges, plizz buy the originally manufactured ones, else ur printer could get damaged! the reason being that the ink head of some compatible cartridges short circuited very easily compared to the genuine ones, and a fake cartridge could damage ur printer in an instance! so, be careful!
Feb 16, 2011 | Canon Pixma MP500 All-In-One InkJet...
ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP500 won't scan.
See to it that no other stickers or lock that won't allow to run of read the scanner in your printer.
Usually this kind of settings are very difficult if also you don't read the manual or procedures on how to use it.
If you encounter like this that your printer won't scan. Not for thinking but you send it to Canon Center or Computer Shop near in your place.
Good luck.
Please rate us!
Oct 06, 2009 | Canon Pixma MP500 All-In-One InkJet...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Error U071 ;more than one ink tank for black
your chip may get something wrong if the sensor is dirty or some ink goes over it!try to pull out the Bk carige and put it back again if not help try same but get some tishue and clean up the chip contact serfice!
Aug 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
4,343 people viewed this question
Clive
Clive
old marine
old marine
