I have an Estate 8cycle 2speed washer that won't fill unless the temperature selector is set to Hot/Cold. Any ideas on what I need to check first?
  • 49 Answers
I bet If you switch the water hose around it will fill on cold and not hot. Reason I think so is that hot fills and doesn't use the cold line. So either you got a bad cold valve or a blocked screen. Also Try to run the hoses into a bucket and see if they run well to eliminate the water source.
Posted on Nov 11, 2013
reg501
  • 413 Answers
SOURCE: Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Posted on Jun 28, 2008
hiltonjug
  • 612 Answers
SOURCE: The washer will not fill when the temperature is
It's going to be your timer. It has points inside. The point the sends power to your selector switch at the beginning of the cycle is burned.
Please ate solution
Posted on Sep 08, 2009
rickead1
  • 1998 Answers
SOURCE: Kenmore washer 80 series model 110.22892100 only
so if you set the knob to cold then the knob would automatically move to hot correct first thing to do is check the water valve which is where your hot and cold hoses connect to inside the machine you get to this from inside the machine by removing the cover one side f the valve is hot and one side is cold take a multi meter and check to assure that when you do set the selection to cold that you are getting power to the top of the valve on the cold side if you are not getting any power to the cold side of the valve replace the valve if you are getting power to the cold side the next thing t check would be that switch that is your selector nob for this you would have to go into the area where your timer is located and check for any burn spots on the small electronic piece that is on the back side of the switch most of the time it is the valve that goes bad and it is a rarity that the switch would go bad but it is possible please remember to rank how this opinion has helped in your appliance situation and if you have anymore questions please message me back have a great day
rickead1
Posted on Aug 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 202 Answers
SOURCE: I have a Kenmore washer
Your mixer valve is for sure bad..
Posted on Mar 22, 2011
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
The washer will not fill when the temperature is set to cold. However, the washer will fill if the timer is advanced to rinse (which is always cold). This occurs for both regular and delicate cycles. Is...
Please ate solution
Sep 08, 2009 | Maytag Washing Machines
My washer won't fill up what is the problem?
Hot and cold tap water valves not turned on.
Bad water inlet valve.
Bad control or temperature selector switch.
The water level sensor is bad.
Or you could have only the cold water hose hooked up and selecting hot wash only. Or you have the hot hose hooked up only and selecting cold wash only. Try selecting a warm wash and see if you get cold or hot water only. If you do, you'll know which is missing.
Jul 28, 2009 | Whirlpool Washing Machines
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
Regards,
reg501
Jun 28, 2008 | Washing Machines
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
Top Washing Machines Experts
