Question about Clothing
Distribution centre
10a Stonedon Drive East Tamaki
2002 pt cruiser had and tail lights will not work al other lights work
Could be a defective multifunction switch but 15A FUSES 2 and 8, 25A FUSE 1, 20A FUSE 15, 10A FUSE 20, and 10A FUSE 19 in the fuse block should be checked as well as 15A FUSES 12, 16/17, and 19 in the power distribution center. Also check the headlamp relay.
Mar 21, 2017 | 2002 Chrysler PT Cruiser
Radio comes on but no sound out of speakers
10A fuse 13 in the power distribution center must be OK because you say the radio is getting power. 10A fuse 16 in the fuse block could be open
Nov 15, 2012 | 1999 Plymouth Neon
After replacing the timing belt and resetting the timing correctly all of the sudden there is NO FIRE to the system from the battery.The car will turn over but no spark.NEED HELP, if anyone has an ide
Breeze, 4 cylinder: check fuse # 5 (20a), fuse #1 (10a), fuse # 10 (10a)- in the power distribution box. Check for power to the coil on the dark green wire with orange stripe. If power there, test the coil. If coil is good, suspect the cam position sensor or the crank position sensor.
Breeze, 6 cylinder: check fuse # 5 (20a), fuse # 10 (10a). Check for power to coil on the dark green wire with orange stripe. If no power to coil, try a new or known good Auto Shutdown Relay (in the power distribution center). If still no power to coil, may be a problem in wiring harness. If there is power to coil, and still no spark, test the coil. If coil is good, suspect the cam position sensor (in the distributor), or the crank position sensor. If all check good, may be a problem in the wiring or the pcm (computer).
Good luck.
Jun 07, 2012 | 1996 Plymouth Breeze
Are the memory cards for this machine still available? I purchased this model second hand and memory card 102 is missing and i would like to purchase it. I live in NZ
hi,
you will find ebay the best place to find card accessories for this machine. i have found heaps of cards for the 9000, including the 102. look for numbers with 3 digits for the 9000, 2 digits are for the older 8000, though they will work for the 9000 they are smaller and simpler designs.
ENHMC is another card label that works in our machines, made by amazing designs as after market cards. There are scanners and things second hand but they are a bit difficult. i find i get heaps of designs that you just pop in the machine.
Jul 20, 2011 | Janome Memory Craft 9000 Computerized...
I have been given a 2005 model sewing machine without foot control or power cord. How much and nearest supplier? Allison Dunedin New Zealand
I would suggest you contact Elna NZ, they should be able to advise price and availability or direct you to a local dealer.
Elna Australasia
icon_mail.gif A division of Janome New Zealand Ltd
Unit 5/325 Ti Rakau Drive
East Tamaki
Auckland
New Zealand
icon_mobile.gif +64 9 271 4148
icon_printer.gif +64 9 271 4149
icon_mail_back.gif john.sherman@elnaaustralasia.com
Jul 09, 2011 | Elna 2005 Mechanical Sewing Machine
Where is samsung s630 digital camera's service center in Mumbai?
Purnima Sales Services Centre
Electronics & Home Appliance
Goregaon East,Mumbai
Fine Tune Service Centre
Andheri West,Mumbai
Balaji Electronics
Electronics & Home Appliance, Cellphone Repair
Chembur West,Mumbai
Maya Steel Centre
Andheri East,Mumbai
Sep 04, 2010 | Samsung Cameras
Where can I find headlights fuse in 1995 Mercury Villager ? I know the fuse box is inside the car under the steering wheel, but that's not for headlights fuse.
IF HAVE AUTOLAMPS
IP FUSE/RELAY PANEL fuse 26 10A & fuse 20 RLY COIL 10A
POWER DISTRIBUTION BOX UNDER HOOD
H/LAMP 15A
IF DAYTIME RUNNING
: i/p fuse relay panel fuse 20 RLY COIL 10A
fuse 3 ENGINE CONT 5A
: LH COMPARTMENT FUSE/PANEL
H/LAMP LH 15A
H/LAMP RH 15A
WITHOUT DAYTIME RUNNING LAMPS
: LH ENGINE COMPARTMENT FUSE PANEL
H/LAMP LH 15A
H/LAMP RH 15A
: I/P FUSE/RELAY PANEL
#19 TAIL LAMP 15A
Feb 05, 2010 | 1995 Mercury Villager
No display
AMD Headquarters:
One AMD Place
P.O. Box 3453
Sunnyvale, CA 94088-3453
View Map
Tel: 408-749-4000
Other Corporate Offices:
AMD Austin, Lone Star
Advanced Micro Devices
7171 Southwest Pkwy
Austin, TX 78735
View Map
Tel: 512-602-1000
Please Rate Me
May 29, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
Seal/Gasket missing on Braun Blender
Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
Auckland has a Service Centre:
0.gif Key Service Ltd
7D Echelon Place, East Tamaki, Manukau City Auckland
P.O. Box: 38569 Howick
Manukau City
Phone Country Code: +64
Phone: 09-916 0960
Fax: 09-916 0970
Service for: All products
Otherwise, you can locate Service Centres in Australia.
Apr 13, 2009 | Braun MX 2050 PowerMax Work Top Blender
I bought Nakajima Ax-530 typewriter.Need user manual.Where can I get it?Please help.
Ntry here!orth American Distribution
425 East Arrowhtttttffead Drive
Charlotte, NC 2http://www.nadist.com/8213
North American Distribution
425 East Arrowhead Drive
Charlotte, NC 28213 North American Distribution
Charlotte, NC 28213
Phone: (800) 809-7138
Fax: (800) 809-7153
Email: Service@NorthAmericanDistribution.com
Fax: (800) 809-7153
Fax: (800) 809-7153
Oct 15, 2008 | Office Equipment & Supplies
Clothing Logo
274 people viewed this question
Top Clothing Experts
ray gallant
Da Doc
Bill Boyd
Are you a Clothing Expert? Answer questions, earn points and help others
