Question about Exercise & Fitness
I have a VL0901 treadmill that displays error 9 when I turn it on. How do you clear this as nothing works.
    Top Expert:
  • 12,223 Answers
Follow this troubleshooting and fix it. God bless you
Error 09, Lower PCA Memory Test Error
Probable Cause Most commonly indicates a problem with the lower PCA when the error consistently appears. It is rare for a failure to occur that would cause this error.
Corrective Action
  • The lower PCA should be replaced if the error consitently appears at power up.
    1. External causes may make the error appear intermittently.
      1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
      2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittent
    Posted on Jul 29, 2013
    2 Suggested Answers
    SOURCE: My VL0901 treadmill displays an E4 error as soon
    You must plug the safety cord in if it is in just make shore the contacts r clean
    Posted on Aug 20, 2011
    How do i fix a lifegear treadmill 97520?
    Try below:
    ERROR CODE
    DESCRIPTION
    E1
    Speed error (The treadmill running speed is 3.2 kph faster than the displayed
    speed). The treadmill will stop immediately when the console detects this error.
    E2
    Speed error (The treadmill running speed is 3.2 kph slower than the displayed
    speed). The treadmill will stop 16 seconds later after the console detects this
    error.
    Troubleshooting / Resetting error codes
    In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
    the computer by:
    1. Step off the treadmill. Ensure that you are clear of the running belt.
    2. Turn the treadmill off at the master power switch located near the motor housing.
    WARNING: Ensure nothing is positioned near or under running belt which may possibly block
    it's normal operation.
    3. Turn the treadmill on at the master power switch.
    4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
    reinstalling the Safety Tether Key can also reset the display.
    If the above does not clear the error code, please contact the nearest Dealer/Service Center
    LifeGear 97320 Owner Manual Page 17
    May 22, 2016 | Exercise & Fitness
    Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    True Treadmill Errors and Service Messages
    • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
    • The error messages that may be displayed by the built-in diagnostics are as follows:
      • E1:INCLINE
        • This means that the incline is moving when it has not been commanded to.
      • E1:MINIMUM
        • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
      • E1:RANGE
        • This means the difference between the treadmills zero position and maximum incline is not sufficient.
      • E1:STALL
        • This means that the incline is not moving when it has been commanded to.
      • E2:OVERSPEED
        • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
      • E2:CAL
        • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
      • E3:EEPROM
        • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
      • E5:SENSOR
        • This error occurs when there is no speed or RPM feedback detected from speed sensor.
    • The service messages that may be displayed by the built-in maintenance reminders are as follows:
      • S1:LUBE
        • This service message displays when it is time for inspection of the deck lubrication system.
      • S2:CLEAN
        • This service message displays every 500 miles and is your prompt to clean the treadmill.
      • S3:MOTOR
        • This service message displays every 2500 hours and is your prompt to check the motor brushes.
    • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
    Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
    Oct 12, 2015 | Exercise & Fitness
    Precor gfx 9.33i displays "stuck key"
    Precor Error 05, Key Depressed at Power Up
    Probable Cause 1. A key is permanently depressed on the display.
    2. An interface chip (IC) has failed in the upper PCA's keypad.
    3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
    Corrective Action
    1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
    2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
    3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
    This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
    Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
    Apr 20, 2014 | Precor Deck, Treadmill, OEM
    I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
    see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
    When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Stairmaster quinton 612 plus error code e201
    Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
    Corrective Action
    1. Use Up or Down arrows to bring grade into range.
    2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
    Quinton Treadmill Error Codes E201
    Mar 16, 2012 | Startrac Fitness Products Exercise &...
    ERR on the treadmill when I switch on. how do I fix and get working
    Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
    Nov 16, 2011 | Kettler TX3 Folding Treadmill
    My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
    From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
    1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    2.Press the "ENTER" button three times to access the treadmill's error log.
    3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
    I hope you find it very helpful.
    Sep 04, 2011 | Exercise & Fitness
    E 7 error code is displayed on my SportsArt 1210 treadmill. When keep it turned off for a long time, then the machine works fine but if I switch if off and back on again, E 7 is displayed and nothing...
    i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is srt8ght1999@yaho.com. not posting my number here.
    Jan 05, 2011 | Exercise & Fitness
    Exercise & Fitness Logo
    315 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
