Bose remote control what remote do i need for a arwcc6 unit
2 Suggested Answers
SOURCE: I need a replacement remote control - Bose RC9
I have same problem with RC-9 working intermittently with some light banging. Thanks for the tip above. I tried opening the remote but the case wont open. Is there an easy way? Dont want to break the case while opening. Thanks.
Posted on Dec 29, 2009
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
Feb 17, 2013 | Bose RC-25A Remote Control for Lifestyle...
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
My dish network remote will turn the bose unit on and off, forward dvd and ect. It will not turn up the volume.
It may be that you are not using the correct code for yourparticular Bose component. I would recommend trying all of these codes: 761,664, 656, and 639. If you are still not able to use your DISH remote to controlthe volume of your Bose component, try doing a power scan. Press and hold theAUX button on the top of your DISH remote until all the mode buttons on the toplight up, then release. Press 2 then * on the number pad, press the powerbutton at the top of the remote, then keep pressing the up button on theremote. Continue doing this until your Bose unit turns off, once it has, stoppressing the up button and press the pound (#) button. Check that the code works by trying several differentfunctions on the remote to make sure it properly operates your Bose component.Keep in mind that some codes may not be compatible with your equipment.
Thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Support Representative
Nov 21, 2010 | Bose 35503 Remote Control
I have a Bose Lifestyle V30 surround sound system and the Bose remote does not function with any of the listed remote codes for the Panasonic. I have a Panasonic TC-P58V10.
You need to use the IR emitter that came with the Bose V30 system. Bose employs a proprietary RF frequency remote which communicates to the hidden central control head. You plug in the emitter to the processor unit and run the emitters to the IR 'eye's' of the equipment you want to control. Once all this is done then and only then can you go through the remote codes to control a particular device. The Bose V30 has 2 IR emitters that come with the unit to control 2 devices. You can expand on that buy buying a IR emitter bridge that has several inputs for other devices.
Now when it comes to a DVR I am not so sure the Bose universal remote will work all the playback and FF and record control buttons and a DVD or VCR. I hear there is a new BOSE remote on the market that can do that but I have yet to see it in person or ask a sales rep about it. Sometimes they are non-tech's so its no help : (
Feb 10, 2010 | Panasonic Televison & Video
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
My Bose 321 series II is not responding to the control remote commands. Everything else does (TV, VCR,etc), but the BOSE receiver does not.
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Jul 16, 2009 | Bose (321GS) System
Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
Feb 21, 2009 | Bose Lifestyle V30 Home Theater System -...
Need remote
Hi Mike. ?you will have to get the model number off of your radio and contact BOSE so that the remote will be compatible with the radio. You can contact Bose at 1-800-999-2673
good luck with this and enjoy your bose.
Feb 14, 2009 | Bose 35503 Remote Control
Bose 321
I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. Let me wait for a day or 2 receive CD and test it. Have you got any solution.
Dec 28, 2007 | Bose (321GS) System
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
