Question about Dyson DC03 Bagless Upright Cyclonic Vacuum
Dyson dc03 lack of suction
Won,t suck
SOURCE: Loss of suction
Could be the small hose at the base of the machine behind the roller/beater bar. If this is punctured or has come adrift suction is impaired.
Posted on May 26, 2008
chrispurs1
  • 372 Answers
SOURCE: no suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Posted on Jul 05, 2008
SOURCE: No suction at all.
There is probably an object caught in one of the tubes. Or something by the filter.
Posted on May 22, 2009
ukvacfan
  • 328 Answers
SOURCE: no suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Posted on Jun 19, 2009
  • 83 Answers
SOURCE: lack of suction in hose
That popping sound is the bleed valve activating - it indicates that there is a blockage in the machine somewhere, probably in the wand if you're saying that there is no suction in the wand.
- Take the wand off the back of the machine - press the two gray buttons to separate it from the hose - hold the wand in the air and look through it - if you can't see the light coming through the other side there's a blockage in the wand - taka a long object like a meytal hanger and remove the blockage.
If that's not the problem, call the Dyson helpline for further troubleshooting, they know what they're doing.
Posted on Jul 30, 2009
How much does a dc03 weigh
Hi there, it's Jack at Dyson.
I can confirm that the Dyson DC03 weighed 6.9kg.
I hope this helps, but let me know if you'd like any further advice.
Sep 27, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Brushbar not turning
DC03 doesn't use a traditional user-replaceable belt. Instead it has a brush control clutch mechanism which allows you to turn off the brush bar when cleaning hard floors and delicate rugs.
If the brush bar doesn't seem to be rotating, it's worth double-checking you have the brush control set correctly. When the machine is reclined into the normal vacuuming position, the brush control should move to the Drive/On position:
Please note, as a safety feature the brush bar will never rotate when the vacuum is standing upright.
If you're confident the brush control is in the correct position, but the brush bar still won't rotate, please give our freephone UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Sep 16, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
BAD SUCTION WHEN USING ATTACHMENTS
Bad suction often means a blockage somewhere, so check all the possible areas for blockage that relate to the hose. Also, check the hose for splits, as they often split at either of the ends - this would greatly affect the suction when using the hose and tools (and can sometimes only be spotted when the hose is stretched at the end points).
Jul 21, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
BAD SUCTION WITH ATTACHMENTS
You may have a small leak in the hose somewhere, that may be getting bigger, thus losing more suction.
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dc03 making screatching noise when hoovering
I'm sorry to hear you're having difficulty with your DC03. The brush control system is designed to make a ratcheting sound to warn you if something is jamming the brush bar. To check for and remove any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc03/dc03-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-the-cleaner-head-window
This should resolve the issue, but if you'd like any further assistance or advice, please give us a call on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week, and calls are free from UK landlines.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Loss of suction,when used in upright Hose blocks suction does not take dust into the clear cylinder
Hi Jean,
I'm sorry to hear you're having difficulties with your DC03. If it doesn't seem to be picking up as well as usual, it sounds as if the cleaner may have a blockage, and the filter may need a wash. The easiest way to locate and clear any blockages is to follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/help.asp?article=314&product=DC03-SY-STD
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
Following these steps should resolve your issue, but if you're still concerned, please get in touch with us directly by calling free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Nov 07, 2011 | Dyson DC03 Bagless Upright Cyclonic Vacuum
DC03 Clutch Replacement
Hi Mike,
We can't provide directions on replacing a DC03 clutch, as this should only be carried out by a Dyson engineer. If you feel your DC03 isn't picking up as well as usual, you may be able to resolve this with some simple troubleshooting steps:
http://www.dyson.co.uk/support/help.asp?model=SUP-DC03&article=527
If you've tried this and would like some further assistance, get in touch with us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Nov 02, 2011 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Is there anything inside a cyclone bin assembly (Dyson DC03) that could break and prevent suction being transferred to the rest of the machine
If you're worried about the performance of your Dyson DC03, you might find it helpful to follow these simple checks to make sure all the airways are clear and free of blockages:
It's also a good idea to wash the filter. You can find out the correct way to do this in our video guide:
http://www.dyson.co.uk/support/help.asp?article=1938&product=DC03-SY-STD
Please note the filter should be washed at least once every 3-6 months.
Hopefully this should help you resolve your issue. However, if you're still having difficulties, please get in touch with us directly so one of our experts can run through some troubleshooting with you over the phone. You can call us free on 08002980298.
Kind regards,
Jack
Dyson Customer Service
Jul 28, 2011 | Vacuums
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Dyson DC03 Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
