SOURCE: Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse. What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly. I took a thin screwdriver and removed the food from the cavity. Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
SOURCE: lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Reset sequence for Sears Kenmore Elite 630.1630?
Unplug for 40 minutes to reset this unit.
