Question about Exercise & Fitness
Rogerblack treadmill error code E003 - Exercise & Fitness
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my rogerblack compact treadmill ag -11306 has become very loud
1) LUBE THE deck belt, this happen because the lack of maintenance, Maybe your have the deck WORN, and you need replacement
2) Lube the rollers bearing.
3) test the bearing from main motor, need repair.
4) see if there are some loose parts inside.
5) Lube the gear and shaft elevation motor
God bless you
Posted on Jul 28, 2012
ercupa190
  • 12223 Answers
SOURCE: were can i get a rogerblack gold treadmill manual model ag-11302 from
go and download from www.fitness.manualsonline.com
God bless you
Posted on Nov 28, 2012
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
Rogerblack gold treadmill wiring
see the diagrams attached. God bless you
Jul 14, 2013 | Exercise & Fitness
My rogerblack compact treadmill ag -11306 has become very loud
God bless you
Jul 27, 2012 | Exercise & Fitness
Problem with my Rogerblack treadmill
i av gold treadmill model ag10302 and need 2 get mains lead
May 17, 2012 | Exercise & Fitness
I have a problem with copier GP 225 it gives E003 how do I clear this code?
fuser temp not rising at correct pace. could be thermistor,thermal switch or fuser lamp
Oct 07, 2009 | Canon Office Equipment & Supplies
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Apr 30, 2009 | Exercise & Fitness
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
