Question about Car Audio & Video
Is this a factory amp pulled it from my 2006 chrysler town and country limited but cant find it by part number anywhere someone please help
Is this the factory amp
  • Bobby Blomgren Aug 02, 2013
    your factory head unit requires an amp to run you'll need to get an amplifier interface to hook up the back of the stereo and then run wires from there to your new amplifier otherwise you run the risk of burning up wires and the unit won't work correctly
    Problem Solver:
  • 13 Answers
Yes that is the factory amp.
Posted on Jul 30, 2013
  • ryan_nelson6 Jul 30, 2013
    Thank you very much how can I bypass it and still use factory deck
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
How do you disable tmps on 2006 Chrysler town and country?
TPMS-tire pressure monitor system
Is required on most or all vehicles starting in 2008 on
& is a federal law that requires it be there
No way to disable
You can pull a fuse I guess ,but can not go thru
inspection like that
Jan 03, 2013 | 2006 Chrysler Town & Country
How do you repair the drivers side outer CV axle and boot on a 2006 Chrysler Town and Country Limited minivan?
Obtain a Hayne's manual from AutoZone. It will give you detailed directions how to do this.
Apr 30, 2012 | 2006 Chrysler Town & Country
What size battery do I need for our 2006 Town & Country?
  • SLI24 Battery 2001 to 2006 V6 3.8L 500CCA Town and Country Chrysler Car and Truck
Jan 25, 2011 | 2006 Chrysler Town & Country
I need the diagram of the 2006 Chrysler Town & Country fuse block.
For 2006 Chrysler Town & Country fuse diagram, check the Owners Manual (page 434 and next).
Hope this help (remember rated and comment this).
Mar 23, 2010 | 2006 Chrysler Town & Country
How to get back sets removed from Town & country basic 2006 model
To remove the back seats.Lower headrest, fold seat down.Pull up on the release lever at the bottom on the right, tumble seat foward. Pull the release ******** the bottom of the seat to unlock the front
Dec 18, 2009 | 2006 Chrysler Town & Country
Describe your 1996 Chrysler Town &
HAVE SOMEONE EXTRACT THE CODE FROM THE CAR'S COMPUTER. IF THERE IS A CHECK ENGINE LIGHT ON THEN THE PCM HAS A CODE STORED ON IT. IT SOUNDS TO ME LIKE A THROTTLE POSITION SENSOR, BUT JUST CHECK THE CODE TO BE SURE. SOME OF THESE CAN ALSO HAVE A BAD IDLE AIR CONTROL VALVE. I HOPE THIS HELPS YOU TO FIND THE PROBLEM. PLEASE KEEP ME POSTED, THANKS FOR USING FIX-YA. GOOD LUCK
Aug 28, 2009 | 1996 Chrysler Town & Country
I have a 2006 chrysler town and country and it is losing antifreeze somewhere - can smell it when shutting off vehicle but can't see a leak anywhere. Any ideas? I checked the oil and it looks clear so sure...
Look for traces of a light pink residue around the bottom of the waterpump and the radiator core support. The waterpump is near the firewall on the passenger side. If you still can't find the source of the leak you will have to have the system pressure tested. I hope this helps.
Jul 28, 2009 | 2006 Chrysler Town & Country
2001 Chrysler Town & Country Sliding Door Harness
you need to remove the old harness and open it up then repair the broken wires this will save the old harness and what the other people are talking about
Nov 12, 2008 | 2006 Chrysler Town & Country
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
