Question about Maytag LAT2300 Top Load Washer
Washing machine my washing machine was working fine yesterday i went to wash some clothes today and now it want fill up with water are come on
  • Anonymous Mar 29, 2014
    My, electricity went off yesterday, and my, washing machine won't come today
  • 641 Answers
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Posted on Aug 30, 2007
SOURCE:
Just today when I went wash clothes on the express wash it didn't work and I had two letters on my machine LF what does this mean and how an I fixit so it works like it usually does
LF means Long Fill. Lack of water pressure has caused the machine to warn you that it is taking too long. Check the valves on the fill hoses to be sure they are open.
Feb 14, 2017 | Washing Machines
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Jan 03, 2011 | Hotpoint WMA13 Front Load Washer
MY WASHING MACHINE WONT START WASHING
Could be motor brushes or the motor....
Feb 09, 2010 | Washing Machines
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Washing Machines Logo
74 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
