Question about Adobe Photoshop CS2 for PC
PShop I'm trying to batch rename a folder of images, that I have done many times before, but this time, I am informed that some of the files are locked. I am unaware as to how this has happened, and more, how to unlock and resolve. Any help gratefully received
It will be a Read only file thats the problem. Go to the folder if u have copied from the CD. In the folder properties uncheck read only file. These may solve the problem
Posted on Aug 31, 2007
SOURCE:
How to convert 2gb sd card into 4gb
How to convert 1 or 2GB memory stick into 4GB?
Just follow the simple instructions:
Step1: Insert your memory stick in USB port
Step 2: Open the Drive increaser software folder (download the software)
Step 3: Rename the Pendrive or memorystickimage_thumb%25255b35%25255d.png?imgmax=800
image_thumb%25255b32%25255d.png?imgmax=800
Step 4: Open Drive Increaser 2 icon from the Downloaded folder.
image_thumb%25255b6%25255d.png?imgmax=800
Step 5: The opened file is asks USB drive Name. (Before enter the name first Rename the Memory stick or Pen drive). Just enter the renamed pen drive name. Ex: 2341
image_thumb%25255b16%25255d.png?imgmax=800
Step 6: After that, it will ask USB pendrive letter (Ex: H or I or J). Repeat this two times
image_thumb%25255b43%25255d.png?imgmax=800
Step 7: After Drive letter entry some process will be done with Red color like this image
image_thumb%25255b49%25255d.png?imgmax=800
Step 8: Finally it shows Done Please enter any key to done.
image_thumb%25255b56%25255d.png?imgmax=800
Now your Pen drive is 4GB
image_thumb%25255b63%25255d.png?imgmax=800
Jan 12, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Batch convert image files, that keeps a folder tree?
If your not using version 2.20 then upgrade because there is no limit according to the manufacturer.
Dec 14, 2009 | Microsoft Windows XP Home Edition
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
I can't rename folder
FD32 is a FreeDOS download, which is not appropriate/relevant to Windows operating systems. If you are on Windows as indicated, you can rename a file by right-clicking on the file name in either a "My Computer" or a Windows "Explorer" window, click Rename, and then type in the name you wish it to be. Alternatively, you can click on the name and after a short pause, click a second time. This should basically "open up" the file name for editing within the file list you are looking at.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 27, 2008 | Microsoft Computers & Internet
Windows Vista Start Menu
  • Have you checked the default ( *.msstyles) file in the C:WINDOWSResourcesThemesaero.msstyles
  • To edit the start menu you should have Resource Hacker.exe which can be freely downloaded from http://angusj.com/resourcehacker/
  • To actually edit the file Open ResourceHacker.exe and go to File menu, Open...(option)
  • An Open file dialog box appears .
  • Navigate to the specified directoy and if the file is not shown ; select All Files(*.*) from the Files of Type dropdown Menu.
  • Now you should be able to see aero.msstyles (or whichever is the default *.msstyles file)
  • Click on that file and click on Open.
  • Unlike windows XP *.msstyles files you will not be able to see the bitmaps anywhere.
  • So all you have to do is click on Bitmaps on the left side of the tree view of ResourceHacker and select BITMAPS and go to Action menu ; Save [BITMAP] Resources and change the filename to *.bin
  • Note:save the files in a folder or there will be a large no of files in the wrong place.
  • Close Resource Hacker and Create A New Batch file(Create a text file & rename it as *.bat) in the current folder(where the *.bin files are
  • Edit the batch file and paste the following code: rename *.bin *.png
  • Save and run the batch file.
  • Instead of *.bin files you will see many *.png files
  • All these files are actually being used by windows Vista's explorer.exe
  • Among these files you have to search & find all the files which make up the Start Menu of Vista.
  • The only problem is that not only VISTA but even XP's Start Menu is made up of different images (AND not a single bitmap).So finding all the images takes time.But once you have done it, it's easy to customise the start menu.
  • If at all you want to change the images ,you have got to have a image editor and Use ResourceHacker.exe to replace the corresponding Binary files and save it as (say)aero1.msstyles.
  • To apply the theme you must find by googling, a uxtheme patcher which will let windows VISTA to use multiple themes and of-course a win Vista activator.
I hope I've tried my best to tell you all about windows Vista's Start Menu.Any questions can be mailed at:[email protected]
Sep 12, 2008 | Microsoft Windows Vista Ultimate Edition
How do you set the image's filename to automatically include timestamp and date
Dear jeannesc:
I am assuming that you are using ZoomBrowser EX ver 5.8 which comes with the SD750's Digital Camera Solutions disc. Therefore these instruction will pertain to that version of the program.
You can rename image files using four different naming schemes:
1. Image Name + Number (e.g. Vacation_001.jpg)
2. Shooting date + Number (e.g. 20080601_001.jpg)
3. Name + Shooting date + Number OR
4. Shooting date + Name + Number
There isn't a provision for a time stamp naming convention.
To rename a group of images using one of the above naming schemes simply open ZoomBrowser and point it to the folder that contains the images you wish to rename. For this example let's assume it was your recent vacation photos.
I would utilize either Zoom or Scroll mode to view the images on the main screen. Then follow these steps:
1. Click the task panel labeled "View & Classify"
2. Next click the sub panel "Rename Multiple Files"
3. On the left hand panel click Step 1 "Select images"
[Here you can select any or all images in the folder]
4. Next click Step 2 "Specify Rename Settings"
5. Select the way you want the files to be named and enter
the appropriate settings. Note: If you wish to keep the original
file and make a copy with the new naming scheme make
sure you check "Make Copies of files"
6. Lastly click Finish and your newly renamed files will be there
in the folder.
Hopes this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Photoshop automate-batch rename
I think Photoshop renamed all pictures using the wrong extension. If you can open images with Windows Fax Viewer, they should work in Photoshop too. Check the extension of the photos, they should be JPEG with a .jpg extension. If not, try to rename them using the .jpg at end of the file name. I would be very surprised if Photoshop cannot recognize photos that Windows can. Tell me if this works because ther is another way but I need to know what extension it is currently.
Dec 20, 2007 | Adobe Photoshop CS for PC
Adobe Photoshop CS2 for PC Logo
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
