Question about Haier Microwave Ovens
Door wont open
Hi, My Haier 0.7 Cu ft 700-Watt microwave door switch is broken. As soon as I plug the cord into the receptacle, the oven turns ON. I can't stop it nor control it with the timer. What do I do? Kindly help!
    Top Expert:
  • Haier Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Posted on Jul 29, 2013
4 Suggested Answers
  • 13 Answers
SOURCE: How many power levels does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK have
The 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK has 10 powerlevels with electronic touch controls.
Posted on Jul 15, 2012
  • 13 Answers
SOURCE: How much does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weigh?
The Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weighs33.1 lbs (15 kg)
  • 13 Answers
SOURCE: What is the size of Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK?
The of the Haier 700 WATT MICROWAVE TOUCH 0 7 CU FTBLK is 17" W x 10 3/16" H x 12 7/8" D.
Turns on when door opened
There is an power interlock inside the oven that breaks the power connection to the magnetron when the door is open. Most likely, something is stopping the switch from opening.
Check for a small plastic probe on the door that may have broken off inside the oven keeping the circuit made. Otherwise, open the oven and see is some foreign object is keeping the connection made or if the interlock needs to be cleaned out so it can function.
Jul 11, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Microwaves fan and light on permanently
One of the relays is stuck. Hit it firmly and see if the fan turns off
Nov 28, 2013 | Sharp 2.0 cu.ft. 1200 Watt Microwave -...
After a power surge, the display comes on. Yet, the buttons do not work. Is there a button to reset?
Is this a one time event? Try unplugging the unit from the wall for at least one hour and plugging it back in. Open the door and close it. I'm not familiar with this particular model but I have to guess that you push the stop/reset button to set the clock after plugging it in. It may be a bad touch pad or a bad door sensing switch.
Sep 19, 2013 | Danby Designer Series DMW077BLSDD 0.7 cu....
Jul 15, 2012 | Haier MICROWAVE TOUCH
Hi our Haier HMW31AEDS microwave has the following problems. 1. It starts itself as soon as we shut the door. 2. The keypad does not work. 3. The only way to turn it off is to manually pull open the door...
I am 90% sure the running as soon as the door is closed is a bad door switch. This could possible explain all the issues with the unit. I would check that first
Nov 21, 2009 | Haier Microwave Ovens
Microwave Ovens Logo
286 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
