Question about i-mate JASJAR Smartphone
Crarging scocket sir I want crarging scocket circuit diagram or the jumrer's of the charging scockets becouse it charging but it show USB not Reccognized on computer and the charging scocket pin's points tracks are break so plz help me and give me jumpers daigram or Images.....plz plz...
    Problem Solver:
  • 17 Answers
Check xda-developers.com
Posted on Sep 13, 2007
SOURCE:
How do the machine work
Please expand your question. Are you trying to thread, wind the bobbin, install a presser foot, install a needle, what?
Mar 23, 2017 | Sewing Machines
Dashboard lights dim in and out and 1 headlight doesnt work.
Sounds like the altenator is failing, [ headlight just may be blown or corroded scocket ].
Jan 12, 2011 | 1990 Ford Ranger SuperCab
Tail light bulb installation for a 2000 Buick LaSabre
In the rear of the trunk you will find several plastic wing-nuts that hold the liner and the light housings to the rear panel. Remove these, pull out the housing, the bulb scockets twist out after releasing the locking tab [ push on lock to center of scocket to release ]. When reinstalling housings to panel make sure rubber sealing washers on the studs are there or water will leak into trunk. good luck.
Dec 31, 2010 | Buick LeSabre Cars & Trucks
I have the endurance jumpstart i need to know how to charge it so i may use it
a charger of the wright polarity and volts (12-14.5volts) that can charge at say 500ma and fits the charging scocket in the power pack will charge your power pack up ok
Mar 28, 2010 | Black & Decker Jump Start System 450 Amp...
O2 sensor problems. How difficult is it to repair ???
there are 2 up stream sensors (before the cat)
and 1 or 2 down stream sensors (after the cat)
most can be done with the special scocket you can by from autozone for 10.00 dollars
Mar 08, 2010 | 1998 Cadillac Catera
How to change serpentine belt .05 UPLANDER
pasenger side of the car ther will be a Tensioner pully (wheel) stick a 3/8" scocket on the wheel ( there is a place for it) and move it to the Right (drivers side) this will slack the belt and allow you to replace it. often there is a diagram that show's you the belt patern, and one of the pullys will have a little arrow that points in. that is the indication of you tensioner pully and the direction it needs to go to release tension. After you have the old off, put the new one on around and release the tensioner pully, and thats is
Feb 22, 2010 | 2005 Chevrolet Uplander
I need to change the spark plugs in a 1997 ford f-150 5.4 literV8
Ahh you gotta love ford for this one. First off the engine has a coil on plug system meaning this is a coil for each clynder. You will first have to unplug the harness from the coil then take a 7mm wrench or scocket and remove the coil hold down screw remove the coil. NOw you will have to go to a tool store and buy a long flex head 5/8 spark plug scocket to get the plugs out. also when you put the new ones in put some antiseize on teh threads of the pug. Good luck its kinda a pain in the but but you will save some money i believe on some of the fords book time is from an hour to three hours depending on what truck or van it is.
Jan 10, 2009 | 1997 Ford F150 Regular Cab
DVD drive replace
If its in a desktop ist simple you need to unscrew the back panel and then unscrew the side cd drive panels , remove the IDE cable from Scocket
Dec 15, 2008 | Sony Toshiba Qosmio F45-AV411 Notebook
1986 ford iveco daily
you could try getting a scoket thats the size of the bush and a scocket bigger each side then get a bolt and nut and wind the bush out by thihtening the nut
Feb 18, 2008 | Baby Gear
i-mate JASJAR Smartphone Logo
55 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
