Question about Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
    Top Expert:
  • Kitchen Ranges Master
  • 12,223 Answers
Test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
the fan in my has not stopped working in  a few we - 3d4a01fc-0f8b-4296-b5b5-156b665cafd2.gif
Posted on Jul 29, 2013
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
My ac/heater fan stopped blowing, where is the fan located? The air is still cold just not blowing out.
verify the fuse first!! the blower is located behind glove box, see it under it and only need to remove 4 phillips screws!
Jun 01, 2010 | 2001 Isuzu Trooper
Fan Blower Makes noise
Sounds like the fan needs to be replaced. But first, to check for obstructions, remove the carpet liner from the underside of the dash on the passenger side and you'll see the blower motor under the dash held in with three screws. If there's something obvious blocking it, remove it and reinstall the fan. If there's nothing blocking it, then you'll probably need to replace the fan. Any auto parts store, Rockauto.com or E-Bay will have the correct fan for your Grand Prix.
May 26, 2010 | 1998 Pontiac Grand Prix
Dell inspiron is turning off randomly
Sounds like overheating, daughter had same problem. Don't blow air thro cooling element on the back of the laptop, you'll blow any accumulated dust/fluff back into the fan, which will just blow back into the cooling element when the fan switches on or it'll stop the fan from rotating altogether. First turn it over and take the battery out, then remove the big L shaped cover from the bottom. There's a thick copper conductor leading to the cooling element' GENTLY lift the cooling element clear of the laptop base, using a soft brush remove any dust/fluff from the element. Then using canned air blow from the bottom of the laptop thro the fan to clear any dust/fluff. Once cleaned GENTLY push the cooling element into position and replace L shaped cover, replace battery and away you go. Daughters has been OK for a few weeks now, amazing how much fluff collects in those fans.
Hope this works! Gaz P
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Heater fan stopped working
check the back of the fan switch for power and inspect it for damage ,melted or loose connections.
May 25, 2009 | 2002 Ford E350
1998 Honda Accord interior ventilation fan has stopped working.
they are right the air conditioner has nothing to do with the fan running .. your air conditioner is operated by a pressure switch .when it gets low on freon it will not come on, which saves your compressor. your fan only blows the cold air the air conditioner puts in to the coils located inside your dash. which the blower then blows the air into the car.. now you are on the right track look some more you will find the round motor under that dash near the glove box and its held in there with usually 4 small bolts. and removal is easy if you can locate it.. one wire and 4 small bolts and out it comes .. you should be able to get one at a local parts store ..
Feb 08, 2009 | 1998 Honda Accord
1996 LX - Condenser Fan Blows Fuse
Check the cooling fan relay under the hood on passanger side.
Aug 17, 2008 | 1997 Honda Civic
The fan blows but the humidified air stops after 2 seconds?
This is an old post, but you can make sure the humidity adjustment is full high. Perhaps it is defective or possibly, the environment is as humid as the high setting will allow.
Feb 08, 2007 | Bionaire BU4000-UC Humidifier
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
