Player no longer works because cannot charge or plug into power. When attapter is plugged in, the power light does not come on unless you wiggle the connection. As you wiggle the light goes on and off, but will not stay on. I went to radio shack hoping it was the AC adaptor. No such luck does the same thing with a new adaptor. Any suggestions or direction would be appreciated.
If it's not the cord itself its the female plug in on the main board of the dvd player. There is little you can do about this as it is soldered onto the board and can not be replaced except by an experienced electronics repair technician.
The cost of having such a thing done would be nearly as much as buying a new one. If it is still under warranty then you can send it in to the manufacture to have it repaired or replaced. If not then you will have to decide upon having it repaired (portable dvd players are meant to be thrown away when suffering from such damage) or you can buy a new one.
Sorry about your misfortune, and thank you for trying Fixya!
I have a Dynex DX-PDVD9A player that I want to ged region free I have used the information about how...
(More)
I have a Dynex DX-PDVD9A player that I want to ged region free I have used the information about how to do that but It only shows me the region that the player is set on but using upp or down butons (6.)dosen't do anything. can you help me?Press SETUP Press RIGHT, RIGHT, RIGHT Enter 9, 6, 5, 3 Enter 0 (or select region code with the arrow keys) Press SETUP
ac/dc adaptor input ac - 110-230v 60/50Hz 0.5aA output dc 9v 2000mA we need a new one, the wires...
(More)
ac/dc adaptor input ac - 110-230v 60/50Hz 0.5aA output dc 9v 2000mA we need a new one, the wires broke too close to be repaired
I have an Audio Vox Portable DVD, model 1988. I insert movie and it does not spin. Shall I just...
(More)
I have an Audio Vox Portable DVD, model 1988. I insert movie and it does not spin. Shall I just pitch it in the garbage?
Will not load dvd's. Have tried cleaning lense but no use. reads loading.. loading.. no disc every...
(More)
Will not load dvd's. Have tried cleaning lense but no use. reads loading.. loading.. no disc every time.
