Question about Ovens
Ilve Manual 864PCM\I
NEED THE SERVICE MANUAL OR PARTS BREAKDOWN
Any suggestions on how to remove covers on lights in Ilve oven so I can replace globes? Tried warming oven as suggested but they wont budge. Is the only solution to get an Ilve technician?
when you go to the service agent to get the correct bulbs ( (need to be pyrex glass ones as normal bulbs will not stand the oven heat) ,ask them how to remove
the fat from cooking gets in the glass threads and then goes to carbon , making it very hard to turn the covers
maybe a oven cleaner sprayed around the glass may help release the threads
Jan 14, 2018 | Ovens
I have an Electrolux EW30EW65GS7 double wall oven and want to replace the baking element for the top oven. Is this done from the front or the back. I have the part and the oven is out and on the flo
Thank you for your post, Richard Gardner!
I understand that you need to replace the element inside of your Electrolux wall oven. I was unable to locate any specific step by step instructions on the removal and installation of your element. I have attached a copy of your parts manual and that provides a breakdown of all the available parts within your wall oven. If you need further assistance I would recommend having a professional technician out to properly remove the element and install the replacement part. I hope this information is helpful to some degree. -Matt
Jan 17, 2015 | Electrolux Ovens
I have an ILVE oven and the door is not closing properly so heat is escaping from top left and right sides, discolouring the white frame polyurethane. How do I adjust the door so that the bottom comes out...
Hi david23413, it's the ILVE service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
May 22, 2011 | Ovens
How do i remove the oven door on an ilve p90 series?
You need to lock the oven hinges out with a pin, you can read how to do this at the link below
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Ovens
Ilve instruction manual
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Dec 26, 2010 | Ovens
Broken oven switch
Hello- Parts for this unit are available directly from the manufacturer. Contact them through e-mail or phone at Ilve.com.au  They should be able to get you the part. Although I'm 'up-top' in the US, and not familiar with how difficult replacing the switch might be, looks like they have service support so ask questions! Please acknowledge this post if helpful. Thanks- Ed
Mar 23, 2010 | Ovens
Ovens Logo
111 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
