Question about Lexmark Wheelwriter 1500 Typewriter
IBM 1500 by Lexmark
Characters a,e,j,and i are indistinct, a smudge appears to the left of the j and the a is filled in. This is visible on the ribbon as well as the typed letter. Tried new type wheel, ribbon but no change in problem. It looks as if the ribbon might be moving as the hammer is struck. Any ideas would be greatly appreciated. Aloha, Bill Monroe
    Sergeant:
  • 279 Answers
If it is moving as the hammer is struck, then it's one of two things. Either the hammer is moving too slowly, or the ribbon is moving too quickly. Since this is a rather old machine, it seems more likely things would slow down than speed up. I'd check the hammer solenoid. See if it's dirty, or needs lubricated. I wish I could give you more advice on this, but I am not familiar with this specific model, and was unable to find any kind of service manual, or troubleshooting information for it.
Posted on Aug 30, 2007
SOURCE:
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
Please help i have urgent work to type but my IBM Wheelwriter3500 by LEXMARK is typing half characters
Half characters? Top or bottom? Please remove the ribbon and reinstall it. Likely it got folded. Make sure as well that the correction tape is properly seated. Otherwise it can get in the way. Unless it is a multistrike, you should see the characters imprinted on it. Just like Columbo when he solved another ****. Good luck.
May 25, 2011 | IBM Wheelwriter 30 Typewriter
Our company has an IBM Wheel Writer 1500 and I need to know how do I adjust the pitch and how do I install the correction ribbon?
Download the manual for your machine form lexmark support pages (go to the bottom of the page, open "IBM Typewriters" list box and select rour typewriter model):
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Jul 27, 2009 | Lexmark Wheelwriter 3000 Typewriter
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM 1500 by Lexmark
It sounds to me like the impression is to heavy try holding the code key down and pressing the "Q" key until the "1" light is lit.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
Characters fill in intermittently.
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
IBM 6400 model i10 print problem
It's likely a "hammer" is defective. This can be caused by
a build up of ink under the ribbon shield and/or around the hammer "fret" itself or the fret is physically broken. Remember
that this is a "shuttle" printer and each fret covers anywhere from
one to three characters depending on model. Some cover fractions of characters as well. The problem will appear as either
data missing on the left or right margin or a blank column of missing data going down the page.
A technician is required to solve all of these problems as the
shuttle assembly must be removed.
Jul 27, 2007 | IBM 6400 Model i10 Matrix Printer
Lexmark Wheelwriter 1500 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
