When my computer starts the cpu fan runs very sound and that time no display and that time burning smell coming
    Brigadier General:
  • 3,400 Answers
TAKE IT APART AND CLEAN IT.ALSO REMOVE THE PROCESSORS FAN AND HEATSINK CHECK THE THERMIC PASTE.
Posted on Jul 29, 2013
SOURCE: no display no beeps but cpu is fine,power led is on and fans are running
Have you upgraded the memory?
Posted on Nov 09, 2007
SOURCE: Hello, I have an E-machine
POWER CONNECTOR ON MOTHERBOARD HAS GONE BAD. CHEAPER TO REPLACE BUT CHECK MANUFACTER TO SEE IF UNDER A WARRENTY.SOME WILL GIVE CREDIT ON A NEW BOARD.
Posted on Nov 30, 2008
  • 2692 Answers
SOURCE: starting proplem
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Posted on Jan 19, 2009
knatcal
  • 53 Answers
SOURCE: I have a EMachine T6534 which won't start. I shut
Most computer repair shops have a tester that they can hook up to your power supply. You can also purchase one for yourself, they usually run $25-50, it may be viable to purchase one if the shop will charge that much to test.
Posted on Sep 02, 2009
Scottshak
  • 14 Answers
SOURCE: I am able to turn
093aba5.jpgYou have a problem with your SMPS. Kindly send your SMPS to a repairing shop. If the guy suggests you to buy a new SMPS then there is hardly anything that u can do instead of buying a new one. I had the same problem once had to replace the SMPS as even after two repairs the SMPS wasn't working properly. There is a prob with the switching regulator for sure if your monitor works perfectly then.
Posted on Sep 24, 2010
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Burning laptop smell Asus x53e
The cooling fan is attached to a heat sync over the CPU. When dirt or dust collect, the fan tends to slow down and the heating becomes intense. Sooner or later, the CPU will shut down and the system will die. Clean with a can of air to remove the debvris.
Feb 26, 2014 | ASUS Computers & Internet
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
Fridge made a burning smell, and now makes a Tick, Fan runs on...
Sounds like the start relay has become bad/defective and it should be unplugged until we can have a look at it closer to see if possibly something other than the start relay is the reason for causing this failure. Depending on your model number a defective defrost control board or fan could start this cycle of damage to the compressor start relay and compressor if not unplugged until repaired. Please see if you can find the model number and I will be able to tell you more about the cause and assist you in the repair, Thanks, Sea Breeze
Apr 25, 2010 | KitchenAid KSRA22CN Side by Side...
Melting plastic smell/ computer slow and shuts down after about 15mins
Hi there.
The reason you can smell burning plastic and why its shutting down after a short time is because its overheating. This can be caused by a build up of dust on the CPU fan, overtime with dust build up computers struggle to keep themselves cool and tend to shut down unexpectedly, chances are this is the problem with your machine, my advice would be to remove the power cord, open the side panel of the computer and clean all the dust away from inside the tower, do this with a soft, clean paintbrush making sure you remove the dust carefully and gently, also make sure the CPU fan and the heat sync behind it is completely free of dust or any other foreign objects.
Once you are happy that its clear of dust, close or return the side panel, plug in the power cord and turn the PC on, you may find that the PC will stay on for longer with the smell dramatically reduced.
Please post back with the results and thanks for using FixYa!!
May 22, 2009 | HP Computers & Internet
Ibm thinkpad t23 shutting off after 10 minutes or so
Your CPU is overheating and the solution is a laptop cooling pad which will save you the cost of another motherboard.
Apr 13, 2009 | IBM ThinkPad T23 2647 Notebook
CPU
this problem comes becauase there may be carbon layer come between proccesor ant the cooling fan.
Apr 07, 2009 | E-Machines eMachines Desktop PC
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
LCD not working
Sounds like a motherboard fault/short, especially if youv'e got on board graphics and if there are smells coming from fan.
Sep 01, 2006 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
