Question about Sherwood RX-4105 Receiver
Antenna is broken
What's the fast and easiest way to fix the antenna on my Sherwood tuner?
  • Sherwood Master
  • 5,126 Answers
Which are we talking about? AM or FM. Is it the socket where the aerial goes?
Posted on Jul 29, 2013
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
I can't get am or fm reception. I can get output from 6-direct input but can't get radio output.
What happens during normal setup test tones?
The tuner requires an antenna and a station tuned for reception. But the audio will not be forthcoming from ANY source (*) if you have a switch out of position like, say, Tape Monitor.
* 6-direct bypasses Tape Monitor all other audio processes and sources. Disable IT.
It's in the manual - page 10.
May 23, 2011 | Sherwood RD-6500 Receiver
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Sherwood SEL-400 Int Amp - Strange Power Issue
I have one with the exact same problem. I think it is in the protection circuit. I am waiting for my tech to have the time to recap and fix it.
Mar 03, 2009 | Sherwood Audio Players & Recorders
Antenna in broken
it can be fixed, it is called a tuner, if you can solder, you can order a new tuner from the manufacturer, and unsolder the old one , and solder on the new one
Jan 08, 2009 | Televison & Video
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
Sherwood RX-4105 Receiver Logo
65 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
