Question about Marantz SR-8000 5.1 Channels Receiver
My SR8000 give loud cracking sound sometimes
Sometimes, it will give loud cracking sound and amplifier stop working/no sound at all when tuning FM. Switch off for more than 30 min, it works again
3 Suggested Answers
  • 20 Answers
SOURCE: my unit sometimes stops playing
No timer issue. I believe thats a thermal problem. After it has been running for a while it might be overheating and shuts itself off. After it cools the thermal switch re-engages turning the unit back on. A few simple things to check are the speaker connections making sure the speakers are connected properly. If you have only two speakers try disconnecting one then the other and seeing if the system still shuts off. If it stays on then you may have a bad speaker. Also make sure the unit has proper ventilation such as making sure its not installed in an enclosure that doesn't have vents. Also make sure there aren't any other components sitting on top or under the unit such as DVD or Blue-Ray players that tend to also run a little warm. Audio amplifiers in general prefer to have at least an inch of clearance above and below to allow air flow. Making sure the unit is clean of dust can be done with a simple shop vac.
If it's none of those things then it may have a thermal issue or electrical issue inside the unit in which case I would recommend having it serviced by a professional unless you yourself are familiar with 110 volts AC safety practices.
-Cheers
Posted on Apr 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: My Marantz 4270 receiver makes a loud crack noise
You need to resolve it or stop using it as those loud noises are dangerous to your speakers.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Jul 07, 2011
It stopped producing sound one day. If I turn the speakers all they way up to ten it will kinda work but it's quiet and it should be really loud.
You don't give anywhere near enough info, so the best I can suggest is to check the amplifier speaker output fuses. Sometimes blown fuses will cause this.
Oct 30, 2016 | The Audio Players & Recorders
Loud distorted noise from the output
well it sounds like a solder pin is getting lose. does it happen when you rattle the vol knob gently? Maybe the potentiometer does also have to be cleaned
Apr 16, 2014 | Marantz Audio Players & Recorders
My speakers are not working. They turn off and on and sometimes make a loud hissing sound. What should I do?
Hello Miranda, Hi, looks like its an amplifier problem, you see the hissing loud sound means that the amplifier section is bad. the amplifier is usually an integrated circuit, this needs replacement, the job can be done by a desoldering the part and replace by another IC. Have this checked by a technician.
Feb 15, 2011 | Car Audio & Video
My 91 3.1L V6 pontiac firebird is driving a bit rough. first of all sometimes when you start to accelerate the engine POPS loud. sometimes just once but other times alot more often. and it sounds very...
Looks like you're engine's skipping and it could use a good tune-up, spark plug and wires, distributer cap and rotor, air and fuel filters and you should be in bisness.
Aug 04, 2009 | 1991 Pontiac Firebird
When ever I hit a crack in the road or anything, vibrating sound?
it could be your muffler plate is loose, thats an easy fix and just a couple of tightening of bolts and it should stop.
Jun 28, 2009 | 2001 Jeep Grand Cherokee
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Loud noise appears to be coming from the engine
what kind of sounds is it making a knocking sound or a exhaust sound might need a tune up
Oct 20, 2008 | 1995 Oldsmobile Cutlass Supreme
Cracking sound from Radio Speakers
I disconnected the amp and ran jumper wires for the proper speakers (two wires per speaker eight total) . Basically I bypassed the amp now all speakers work and sound fine.
Jul 10, 2008 | 2006 Chevrolet HHR
Marantz SR-8000 5.1 Channels Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
