Question about Cannon Office Equipment & Supplies
Head alignment on cannon mx436 printer - Cannon Office Equipment & Supplies
Char1ieJ
  • 100 Answers
SOURCE: i don't know how to
The procedure is in your On Screen Manual. To view the On-screen Manual, double-click the iP2200 On-screen Manual shortcut icon on the desktop, or click Start and select All Programs (or Programs), Canon iP2200 Manual and iP2200 On-screen Manual.
If you don't have access to the manual on your PC, let me know and I'll try to dig one up for you. I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Posted on Nov 23, 2008
  • 126 Answers
SOURCE: What does the code 5100 mean on a mp450 cannon
I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Jan 07, 2009
  • 672 Answers
SOURCE: my document are all too far to the right on the
Support is available at the Canon website, but the support is temporarily down. Take this link at a later time when they are back up and running. The instructions are there. Choose from the pull downs multifunction, inkjet, MP480. Scroll down and enter "print head alignment", click search and the instructions will be available there.
Posted on Sep 26, 2009
  • 15 Answers
SOURCE: printer head alignment is not aligned.
go to "printer and faxes",then right click on the printer ip 1800 and go to the 'properties'.....then click on "clean head".......
do it many times until the head alignment is ok...
Posted on Jan 07, 2010
printerman40
  • 170 Answers
SOURCE: There are horizontal white lines in graphics Cannon MP830 Printer
This sounds to me like you may want to upgrade the firmware also, If your ok following instructions then this should be a breeze...
heres the link to get your firmware:
click here to get your firmware
hope this helps you out and if so please mark fixya...
Posted on Jul 04, 2010
Printing with lines through cannon mx457
Hello. Try to perform a print head deep cleaning. That option is in printer properties in the maintenance tab . If that doesn't work execute a print head alignment.
May 16, 2017 | Cannon Office Equipment & Supplies
My canon c3480 not printing cyan, how can i fix it this problem
First confirm that the cyan ink cart actually has ink in it.
If you do have ink, run a "head cleaning" In the printer driver, there should be a "Maintenance" tab, and in that should be a "Cleaning" button. You may also have a "Deep Cleaning" capability. Try regular cleaning first, and see if that clears the probem.
Aug 17, 2016 | Canon ImageRunner C3480 Color Copier
Ink head alignment test pattern crooked
Go into printers on the computer , click on cannon printer it will have down loaded a manual , all will be explained there.
Aug 10, 2014 | Canon Pixma MX360 Printer
I NEED TO ALIGN THE PRINTER HEAD
In your software utilities, you should have the option to align pinheads. This is also where, once you install a mew print head, it will give you options for test page, and cleaning of the print heads. You can also go to the Canon webpage for troubleshooting tips specific to your model, but I usually do everything through the software bundle that comes with the printer. If you no longer have the bundle, you can go to CNET.com for your software.
Mar 02, 2014 | Cannon Office Equipment & Supplies
Why does my scanner cannon mp160 scan reverse image
Press the Resume/Cancel button.
- If paper is being fed at error occurrence,
the error is indicated after the paper is
ejected.
- If the error occurs, the print head
alignment values are not changed.
- After exit from the error by the
Resume/Cancel button, the automatic
print head alignment will not be re-done
Aug 23, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How do you ajust a print head alignment
jast follow these proces:
go to: start>printer and fax> your canon printer model ( such as ip 1700)/ (right click)> propertige>Maintennence>print head aligment> ok
Then load a A4 sheet. I think you will be success.
Thank you
Jul 02, 2011 | Cannon Office Equipment & Supplies
My document are all too far to the right on the paper. The printer says I should do a head alignment, however, the manual contains NO instructions on head alignments, so I have no idea how to accomplish...
Sep 26, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
238 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
