Question about Samsung 21" FLAT CRT COLOR MONITOR
No picture when pc is turned on monitor flickers on and off then it stays on but thers vertical lines all over the screen
  • 55 Answers
Re: no picture
this problem accure due to vertical o/p ic is failiur so plz checked it from any hardware engineer or if you changed it. you are welcome. i't mostly 9 pin ic on heat sink. it's mostly located at the horizantal _ vertical coil's wire( 4 wire attached with pcb) are placed.
Posted on Nov 13, 2008
0 characters
3 Points
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computer Monitors
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
May 19, 2010 | Westinghouse L1975NW Monitor
Multiple vertical color lines,i take the picture,how can i send you this photo?
There are two ways you can do this.
1. post the image to a site like photo bucket or flicker and post the link here
2. next to the You Tube on the top of the post reply window click the image. This will open a window. Browse to where you have the image saved and click it. This will insert the image to your reply.
Jun 02, 2009 | Acer 22" X223w LCD Monitor
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Dec 15, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
TFT Monitor Dislay fault
this is a hardware issue with the monitor. I hope you kept a receipt with contact information for the seller.
Make sure the cable doesn't have any bent pins too on both ends.
Jun 15, 2008 | Gateway FPD2275W LCD Monitor
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
HP L1706 monitor
your monitor is getting ready to kick the bucket.
Oct 31, 2007 | HP L1706 17" LCD Monitor
Screen has 1 solid bright vertical line
a mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Sep 30, 2006 | ViewSonic G810 21" CRT Monitor
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
