Question about GE Profile Advantium 120 Wall Oven
Rational oven error code 23 - GE Profile Advantium 120 Wall Oven
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Why my rationla keep blewing fuses every 7 months and over heating.
Maybe you didnt put acorrect fuse size so check it on its body or onthe nameplate
Sep 16, 2014 | Microwave Ovens
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
Rational oven users manual
Plz specify the product model no. to get specific manual.
Thanx
Aug 26, 2011 | Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
GE Profile Advantium 120 Wall Oven Logo
53 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
