Question about Vehicle Parts & Accessories
The relay box at the right of the battery. I need the diagram for those. Only the fuse box at the left of the battery is listed in the owners manual. I need to know what each relay is being used for in that box. 2000 ford taurus wagon ffv
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 53 Answers
How is a link that might help you. http://www.scribd.com/mobile/doc/29512430 The relay box at the right of the battery. I need  - 10_10_2013_3_45_26_am.png
Posted on Oct 10, 2013
Heat blower fuse location on toyota tacoma
Hopefully your owners manual or fuse box cover will show you the proper fuse and location.
For me to look up in wiring diagram, my database wants model year, I didn't see that listed?
Dec 16, 2016 | Toyota Cars & Trucks
Horn is not functioning on my 2006 Ford Taurus. I have checked the fuses listed in the owners manual. I however can't seem to locate the Horn Relay. I found a secondary relay box stuck between the battery...
Is the air bag light lit on the instrument cluster ? The horn relay isn't under the hood in the engine compartment , it's in the SJB - smart junction box located inside the passager compartment . Under the dash panel left side . You can take the relay back to autozone because it's not the right one ! The relay is inside the smart junction box ,soldered to the printed circuit board !
Horn Horn
The vehicle is equipped with dual horns. The horns are mounted in the LF frame rail corner behind the front bumper.
The horn system consists of the following components:
  • steering wheel horn switches
  • clockspring
  • horns
  • smart junction box (SJB)
Horn Switch, Steering Wheel Mounted
The horn switches are incorporated within the driver side air bag module in the steering wheel. The switches are grounded and control the horns through the clockspring. For removal and installation of the driver side air bag module, refer to Section 501-20B .
Visual Inspection Chart Mechanical Electrical
  • Horn
  • Horn switch
  • Battery junction box (BJB) fuse 1 (60A)
  • Smart junction box (SJB) fuse 38 (15A).
  • Circuitry
  • Speed control actuator
  • Clockspring
  • SJB
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index
DTC Description Source Action B1217 Horn relay coil circuit failure Smart junction box (SJB) If the horn is inoperative, Go To Pinpoint Test A . If horns sound continuously, Go To Pinpoint Test B . B1218 Horn relay coil circuit short to battery Smart junction box (SJB) Go To Pinpoint Test A .
Any codes ?
Symptom Chart NOTE: Refer to Wiring Diagrams for connector numbers stated in the pinpoint test. Condition Possible Sources Action
  • The horn is inoperative
  • Battery junction box (BJB) fuse 1 (60A).
  • Circuitry.
  • SJB.
  • Horn switch.
  • Horn.
  • Speed control actuator.
  • Go To Pinpoint Test A .
Your best bet , take it to a qualified ford service center .
May 19, 2017 | 2006 Ford Taurus
Fuses
What problem?
______
Lexia 3 lexia3
May 22, 2013 | 1997 Toyota Camry
Where is the fuel pump relay 2003 ford excursion 6.0 diesel
fuel pump relay is located in fuse box under hood on drivers side near firewall. if your fuse box cover does not list what each fuse and relay are for then refer to your owners manual for diagram.
Sep 28, 2012 | Cars & Trucks
Where is the location of the ABS relay?
It would be listed in the owners manual with the fuses - should be in the engine compartment in one of the fuse boxes.
Jul 10, 2012 | 2001 Ford Expedition
Need a diagram for a 1997 ford f-150 4.6l 4x4 drive fuse panel box.
The fuse listing in the owners manual ?
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
The other one to keep in mind is the aux relay panel, this is not well documented in the owners manual
The one in the upper right hand corner of the picture is the Engine Mini Fuse panel, this is documented in the 1997 owners manual, but not in the 1998 MY owners manual for some reason.
Mar 30, 2011 | 1997 Ford F150 Regular Cab
I need to replace the horn fuse in my 1997 mercury mountaineer
In your owners manual go to the index and look for fuses then go to that page. Look for the horn fuse which should be in the fuse box under your hood around your engine, in your owners manual is should tell you where it's located. Find the fuse for it by looking at the diagram on your owners manual and then pull that fuse out. You should have replacement fuses in the fuse box that's in your car, you have to open the car door to get to it. If you don't have that fuse just take it up to auto zone and tell them you need a replacement for that fuse.
Dec 14, 2010 | 1997 Mercury Mountaineer
Fuse box diagram for a 2004 BMW 325ci
Fuses & RelaysThe fuse box is located under the engine hood on the left side, near the upper strut housing or near the battery.
Various relays are also mounted on the fuse box for easy accessibility.
Flashers
The flashers are located behind the bottom center of the lower instrument trim panel.
Review the...
- BMW E36 Fuse Box Relay Layout
- 325ci Owners Manual
Hope helped.
Oct 23, 2009 | 2004 BMW 3 Series
Fuse panal/relay location
The fuse panel is located under the right-hand side of the instrument
panel. Remove the trim panel and fuse box cover to access the fuses.
There is also a Auxiliary relay box
The relay box is located in the engine compartment on the left fender.
For complete diagrams & legends for your fuses & relays see pages 224 - 230 of the owners manual.
Jul 31, 2008 | 2006 Ford F-150
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
