Question about Samsung WEP460 Bluetooth Headset
Do you need to use the original charger - Samsung WEP460 Bluetooth Headset
    Top Expert:
  • Samsung Master
  • 46,690 Answers
Providing the specifications on the charger are the same in every way to the original then you can use it. It must have the same plug as the original that fits in your equipment.
Posted on Jul 29, 2013
I need to charge my tablet to start but it will not charge
Some Tablet PCs ships only to their original chargers , some can also be charged through your computer 's USB connection . Are you using the original charger ?
Dec 14, 2014 | Tablets & eReaders
Audio sonic portable dvd player
the inbuilt battery is not holding charge needs replacement , the charger needs to be replaced to with the original one
Jul 12, 2013 | Televison & Video
I lost my original charger for it so is there another kind of charger i can use to charge it
There are 4 things that have to match up.
Plug - obviously the plug has to fit
Polarity - If the plug fits, this is PROBABLY ok, but the negative/positive must be the same as the original
Voltage - The voltage output should be the same as the original, which will be a few volts higher than the battery. If the voltage output is the same or less than the battery, it won't work. If the voltage is too much higher than the original, it might fry the battery and the charger.
Current rating - If the current rating of the replacement charger is less than the original, it might fry the charger. If it is much higher than the original, it MIGHT fry the battery. You can probably go +/- 20%
Jul 17, 2012 | Razor MX500 Dirt Rocket
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Need to purchase charger - G4m20211-2347-E-16.
the price is $22 as a standard level 4 original batteries but beware of duplicates
Aug 06, 2009 | Electric Bicycle Motor, Bike,electric...
I added led tail lights to my charger, now the turn signal blink faster than normal, do I need a new flasher?
Yes, get a heavy duty flasher to replace the original. The same thing happens if you hook up a trailer w/ lights to a car, the original flasher can't handle the extra load.
Apr 15, 2009 | 2005 Dodge Charger
Not charging battery
this is simple, there are only two things tht can be wrong or faulty:
1. your charger is messed up, or it simple is not an original dell charger in wich case replacing the thing with an original D600 charger will fix it.
2. your battery is messed up and u may need a new one or its not an original
Mind you many parts of a dell are configured only to worked with same model and original pieces so make sure all the parts are real then if the problem persists, check (for the charger) when the wire is wriggled wether the little green light flickers if it does replace the charger if not try the laptop with somone elses battery to see if it works well if it does change batteries if not then its an internal wiring problem and the warranty will cover tht altough it is Highly unlikely that wiring problems will be present...
Apr 08, 2009 | Dell Latitude D600 Notebook
Samsung WEP460 Bluetooth Headset Logo
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
