Question about Garden
The Poulan blower sparkplug is dry as a matter of fact it still looks brand new. Is the carburetor not allowing the gas to get to the sparkplug? Mmmm
    Top Expert:
  • Garden Master
  • 50,084 Answers
The plug will be dry as the fuel is burnt off during running. If it will not start and the fuel is getting through then it will be very wet. o I would say that the diaphrams in the carby are not working properly. Check that he filter on the end of the fuel hose in the tank is not blocked and that there is no air leaks on the inlet let manifold or gasket. You will have to use the choke for the first few pulls to get fuel into the carby.
Posted on Jul 29, 2013
  • 6 Answers
SOURCE: poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
boscia
  • 163 Answers
SOURCE: No spark At sparkplug Gas blower mod.#Ry08544
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Posted on Nov 29, 2008
  • 31 Answers
SOURCE: where do I find a carburetor assembly drawing for
Does the carburetor have a name on it like walbro. if it does just search for the name. and if its a walbro carb. they are all the same from the smallest to the largest.
Posted on Sep 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Posted on Jan 05, 2010
roadtech7
  • 297 Answers
SOURCE: SNOW BLOWER/SEARS 247.887001-NEW CARBURETOR, DON'T
Have you checked for spark? You have drained the old fuel completely, and added brand new fuel,Right?
Is the spark plug getting wet or is it soaked?
Let me know, we'll get it started.
Posted on Dec 10, 2010
I just purchased a poulan lawn mower at Kents. Have not used yet. Can you add unleaded gas to the poulan lawn mower/do you have to mix the gas?
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
May 22, 2011 | Poulan "Poulan" Push Mower
Dont know what the oil gas mixture is suppose to consist of
Your manual (from Sears) states that your mix ratio is 40:1. You will need 3.2 ounces of Poulan "Pro" synthetic 2 stroke oil mixed in 1 U.S gallon of gas or you can mix 1.6 ounces of the oil in a half-gallon of gas. They suggest using the Poulan "Pro" brand synthetic oil. I do also. Synthetic oil significantly reduces wear, allows the machine to run cooler, and burns cleaner with less by-products and emissions. You can view a PDF file of your manual here:
http://www.managemylife.com/mmh/owner_manuals/133702/POULAN-Blower-Gas-1009868L?brand_name_search=952711923++
May 01, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Put new spark plug in new gas clean filter followed starting directions want start
The fuel system may need tending to. It may need new fuel lines, a cleaned fuel filter and the carburetor cleaned and adjusted. If this is an older unit, (even a couple years old) it may require some new internal carburetor parts as well. I don't like being the bearer of bad news, but this isn't always an easy fix. Your specific problem has to be diagnosed and by process of elimination, the problem resolved.
Oct 05, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a poulan 2450 chainsaw and i can't get the primer bulb to **** any gas, the bulb is in good condition however there is gas leaking out of the gas cap in the center of it, do I need a new gas cap and...
You may be overfilling the tank somewhat so that expanding fuel (from engine heat) is being pushed out of the vent. Check the fuel filter for plugging and all of the fuel lines for any rot, splitting, or other damage. The primer bulb is supposed to pull fuel from the fuel filter, then through the carburetor and on to the primer which should push the excess back into the tank through another line. If the above does not allow the primer to pump fuel, then dismantle the carburetor, clean with carburetor spray cleaner, and rekit it. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--theory and troubleshooting. This information applies to most brands of carburetor. Hope this gets you running!
May 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
25cc poulan leaf blower runs but will not rev . it has to build up to a higher but no balls rpm
It may be old gas not allowing it to rev up. or the carburetor diaphragm may need replacing. I would say at 25cc engine is not going to sound or rev up like a more expensive blower.
Sep 30, 2009 | Poulan Garden
Looking for a diagram for a poulan gas blower. Need to know what is in the carburatur repair kit.
Go to www.precisionope.com. This site has a place to look up Illustrated part list. It will probably give you a part number for a diaphragm kit or a repair kit for the carburetor. Of course if you know what carburetor is on the unit, you may be able to find a website to find the breakdown of the carburetor there.
Sep 29, 2009 | Poulan Garden
Poulan leaf blower/vac won't run. It has spark, head bolts are tight, spark plug wet with fuel. (New plug) Any suggeastions?
that's the problem gas when wet won't burn
remove the sparkplug and, dry it off with rubbing alcohol then reinstall prime and, restart
Aug 31, 2009 | Garden
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
