Question about Whirlpool Ovens
Oven fxvm6 Can't set the time (clock). Please let me know how to set the clock. Thank you.
2 Suggested Answers
SOURCE: Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Posted on Feb 12, 2009
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Our power went out, I need to reset the clock. I can't find my book and it showing 5ab bath. I'm pushing the clock button and nothing is happening.
Hello, Thank You for using FixYa. I will be helping you today.hold the clock button for 5 to 10 seconds..
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Ovens
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Logik microwave user manual
Press 'Clock' then 'Stop / Clear'.
The display will show 0
Set the time (it's a 12 hour clock)
Press 'Clock' again
Nov 02, 2010 | Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Re-set Clock due to power black out
Lucky for you(?) I had to reset our clock for daylight savings and checked here before i found my manual. If you're still looking for an answer, press the + & - buttons at the same time, let go and you have 4 seconds to press the + key again to set the time
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Open Questions:
Ovens Logo
282 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
