Question about LG KG800 Cellular Phone
Down loads? Can anyone help me how to download pics to my pc from the LG800? Also how do I change the touch sensitivity on the touchpad? It says to use the settings>other>touchpad...this is not there where else can I go to change this in the phone?
  • Anonymous Nov 27, 2008
    Yes
    Problem Solver:
  • 5 Answers
When I download pics into my phone, I usually open "My computer", then my "my photos" folder, and drag the pictures that I want into the folder the same way I do with my music. I'm not quite sure about the touc sensitivity problem. If you have any questions, my email is [email protected]
Posted on Sep 20, 2007
DO U HAVE A USB CORD IF YES TRY USING THIS
Posted on Sep 11, 2007
SOURCE:
Dell xps m1330 vista home curser jumps when typing
Have you loaded your touchpad drivers? The only time I've ever seen than happen is when the touchpad drivers aren't loaded. The touch is extra sensitive if your palm(s) just barely touch the pad.
By loading the touchpad drivers, you should be all set
Oct 27, 2012 | Dell XPS M1330 Notebook
Cannot change touchpad sensitivity
you could try and down load the chipset for your system you should find it on the dell support page
May 06, 2012 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Hey. I have an Acer One 532h which is driving me nuts as the cursor keeps on jumping while I'm typing. Sometimes my palms are just hovering above the touchpad and not even touching it with the cursor...
There's no real way to change the sensitivity of your mouse, aside from changing the speed. A possible solution would be to use a USB mouse and disable your touchpad. Hope this helps!
Mar 28, 2011 | Acer Aspire One PC Notebook
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
Touchpad too sensitive
You should find the settings are either under the mouse settings, or under the touchpad's own controls, in Control Panel.
Jul 01, 2009 | Dell Inspiron 1525 Laptop Flamingo Pink
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
My touch sensitive panel above the function keys no longer work please help me with an answer thank you
Check settings of your touchpad in control panel. U need to to adjust the sensitivity. If you cant find it, then download a touchpad utility. U need to check in device manager what brand of touchpad u have. It might be an ALPS or SYNOPTICS. u can download it from support.toshiba.com for US model or at toshiba.ca/support for a canadian model. Have a nice day.
Sep 11, 2008 | Computers & Internet
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
LG KG800 Cellular Phone Logo
66 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
