Question about Asrock P4VM8 Motherboard
Serial ATA controller
Ok. thnks in advance: i've created a floppy SATA controller with the Asrock CD, rebooted and start installation of WinXpSp2, while F6 screen appeared i did follow the onscreen instructions (inserted the floppy and so...)ok once choosen the apropiate driver for SATA in winxp.. thew process went ok. I did create 2 partitions with fast NTFS format (bcs of new hard drive)it copied everything but after rebooting the "theres no drive connected Press F3 to leave" (Between: i choose Boot from Hardisk)
    Master:
    Sergeant:
  • 461 Answers
Try fat 32
Posted on Sep 05, 2007
SOURCE:
How to create floppy with SATA drivers (NO mobo CD)
Don't need to use a floppy - copy the files to a USB Flash drive, and when the Windows asks for the source, select the drive.
Apr 22, 2010 | Intel Motherboard
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option...
Hi.
I will explain you the issue.
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
http://www.scribd.com/doc/4864999/sata
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Sep 09, 2008 | Computers & Internet
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
Motherboard sata driver p4vm800
Hi ben,
you can download that driver by clicking on this link:
http://www.asrock.com/mb/download.asp?Model=P4VM800&s=478
You make a floppy disk with this driver & during windows install you watch the bottom of the screen & press F6. Windows will ask you to insert the floppy disk. (Do not forget to remove the floppy disk).
Good luck Ben!
Mike
Aug 11, 2008 | Asrock 775Dual-880 Pro Motherboard
SATA HDD
you need to install the drivers for it when loading windows,,
you are on the right track by pressing F6 however you need to have the FLOPPY DISK that came with your mainboard in the floppy drive..
If you dont have the diskette then ,, the drivers are located on the mainboard cd,, its in the sata / raid folder, there should be a text document in there with the insttructions on creating a floppy with the driver files you will need.
Jul 19, 2008 | AOpen AX4B-533 Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
Asrock P4VM8 Motherboard Logo
252 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
