Question about Refrigerators
Whirlpool side by side not cooling
This box is less than 6 yrs old and about a week ago the coils would just freeze up with ice after thawing it it would work fine for a day or 2 and same problem again. I turned the refridge on it's side to get ez access to clean the coils of dust and dirt and now it dosen't cool at all, the fans and compressor are running but still not getting cold not even a little bit. I tested the temp controlls with a meter and it test good. what might be wrong? Thanks Gene
  • 4 more comments
  • nogojoe Aug 31, 2007
    ok I will give it a try and in a few days see what happens. Any Idea about how much this will cost to repair? Whirlpool is now a cesspool and junk. man what happened to the good ol' days.
  • Anonymous May 24, 2008
    My side by side whirpool start to do some noise at the top/front, days
    after, started to defrost or stop cooling them return to be cold, them stop again.
    We cleaned, and started to cool , but after 48 hours stop cooling.
    The refrigerator is 4 1/2 years old.
    What we can do?
  • sadmommy Sep 23, 2008
    Yes. Neither fridge or freezer will cool. There is intermittent noise that sounds like the icemaker trying to fill. My unit is only 5.5 years old.
  • thunderally Feb 22, 2009
    the refrigerator and freezer settings are at midpoint (4). It works well at these settings but lately i noticed it's not cooling any more. the other night i noticed that water was dripping on the outside from the ice dispenser machine, probably the ice in the storage bin melting. i also noticed that the control settings button were popped out probably by accident. the digital numbers don't show a complete number (one digital line would be missing). i tried turning it off and on again but still no sound from the motor. i opened the bottom grill and cleaned the underneath of the unit, still wouldn't turn on. what other things could i try?
  • Anonymous Mar 25, 2009
    ncnxn
  • Anonymous Apr 30, 2009
    refrigeratro is not cooling.
  • 63 Answers
Your refrigerator had a defrost problem but now after you laid it down it sounds like you gave it a oil restriction when you laid it down there is oil in the compreesor it left the compressor and made its way into the evaporator in whice it has clogged the strianer dryer you will now need system work you could try to unplug it for a few days and then replug it in it might start to get cold if it does then you will have to checkk the defrost system it will either be a defrost timer ot heater ot defrost limiter or defrost fan good luck
Posted on Aug 31, 2007
  • 53 Answers
Refrigerant is leaked out and it needs refilling of the refrigerant and servicing and first you must find out which part of the unit exactly the refrigerant is leaking and then rectify it and flush out all the moisture and dirt from the system and gas charge the same again with recommended refrigerant and change the drier of the unit to avoid partial ice formation.
As you mention that the compressor and relay thermostat are functioning there is no need to touch them.
Posted on Jul 10, 2009
SOURCE:
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Model #GX5SHDXVB03 freezer floor filling with ice (water run down back then freezes)
So I figured out what the real problem is with this model of freezer. There is an updated drain that needs to be installed. The old version gets plugged from dust and no amount of thawing will fix it. if your appliance is less than 2 years old the manufacturer will pay to have your appliance updated with the new part. If your appliance is over two years old they will send you the new part for free.
http://www.amazon.com/gp/product/B0156NFUV4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Feb 28, 2012 | Whirlpool Refrigerators
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Freezer not freezing
Your clicking noise is a defective start relay on the compressor. It must be replaced. You can get the part and do it yourself. Just pay attention to the wires. Replace them on the new relay as they come off the old.
The relay is attached to the side of the compressor.
Mar 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
Feb 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool not cooling properly
I would expect the defrost timer to stay in defrost 21 minutes. IT seems your timer is normal.
If turning the ref section temp colder made compressor come on, it could be that the thermostat is worn a little and just needs to stay on a little cooler setting. Check the freezer temp dial and It should be at just slightly more than 1/2 of available setting. If there is A B C you would want to be a little cooler than B about B and 1/4.
I hope this helps K S
Nov 22, 2007 | Refrigerators
Refrigerators Logo
1,184 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
