Kubota zd18 I have a problem with the mower starting from time to time. I can jump across starter and solenoid and then try to start and it will start. Any suggestions?
michigan man
  • 3533 Answers
SOURCE: 2002 Taurus won't start.
all I had to do on a sable was to replace the belt but look at the battery there should be a wire coming from the battery going to another solenoid mounted under the hood and then going down to the starter get a 12 volt tester and see if you have power going to this solenoid cause it could be dead on one end and not going down to the starter
Posted on Jan 18, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
mickey813
  • 472 Answers
SOURCE: Kubota Z18 zero turn mower won't start.
souns like the key swich is bad ck that
Posted on Oct 01, 2009
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
Mr BrokRench
  • 1623 Answers
SOURCE: 1966 mustang 289. won't start,
Ignition problem... No signal from ignition to solenoid...run a starter draw test to confirm starter is ok --- You can run your jump wires to a remote starter button or switch to get around it for now.
I hope this helps.
Posted on Sep 22, 2011
Mower will not start by key. I can jump across silinoid and mower will start right up no problem.Why is it not starting by the key?
H Albert:
If it starts when you jump across the solenoid, but not when you jump from the positive to the exciter terminal on the solenoid, then the solenoid needs to be replaced.
If it does not start from the exciter terminal short, then power is not getting from the switch to the exciter. Check wiring and switch functions.
Cheers
May 06, 2016 | Garden
Troy Bilt not turning over. Battery charged, new starter, but nothing. Amp gauge registers when turning on key, buts that's it.
First find the starter solenoid. Take an old screwdriver (one that you don't mind damaging) jump across the two main terminals. The start should engage. Next see if the solenoid getting power to it trigger terminal. If it is there replace the solenoid. If not then try applying 12v to the trigger if the solenoid now engages the starter you have either a safety switch that is inoperative or a bad ignition switch.
May 26, 2015 | Troy Garden
All safety switches are engaged still cannot start with key. Able to jump start from mower battery to starter and shut off with key. Help ?
Sounds like it could be either the starter solenoid or the wire from the key to the starter solenoid. Try to energize the S pole on the starter solenoid and see if it cranks and starts. If it starts, the solenoid is not the problem so it could be the wire that goes to the start position on the key switch. If it doesn't start, it's the solenoid.
Jun 11, 2014 | Husqvarna Zero Turn Mower Z5426
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
1966 mustang 289. won't start, jumped across solenoid, started. Replaced solenoid-starter wouldn't disengage, replaced starter, back to square 1, jumping across solenoid to start - whats my...
I hope this helps.
Sep 22, 2011 | Ford Mustang Cars & Trucks
John deere Z225 riding mower won't start .hour meter lights up .jumped across starter solenoid and it started three times and run.replaced with a new starter solenoid and nothing then tried jumping...
Sep 12, 2011 | Garden
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
Wont start starter not engaging solinoid clicking
Try jumping across the 2 large posts on the solenoid, if the starter engages, replace the solenoid
Aug 29, 2009 | Garden
How to tell if your solenoid is back
Probably. Try jumping across the two post. If that turns over your engine, replace the solenoid. Or, another way to check it is to disconnect the wire on your starter, hook a test light to it and turn your key to start. If the test light does not light up, the solenoid is bad. Remember to hold the clutch/brake pedal down when you turn key to start.
May 17, 2009 | Garden
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
