Question about Kitchen Ranges
NEED MANUAL FOR CALORIC PRESTIGE SERIES GAS STOVE ,MODEL rss358uw
Older stove need a manual to learn how to use it...model RSS358UW SERIAL# 9211272432
  • 1314 Answers
SOURCE: Need info.......
i don't think that model has a pilot try the oven and see i think its electronic ignition
Posted on Mar 31, 2008
mikedem7
  • 25 Answers
SOURCE: My gas oven won't heat
it is a bad thermocoupler.
Posted on Aug 19, 2008
  • 15 Answers
SOURCE: caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Posted on Oct 07, 2008
  • 1214 Answers
SOURCE: Hello, Can't find model/serial number.
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Posted on Jan 30, 2009
  • 2328 Answers
SOURCE: model/serial number 12-0506-05/03135-18204133.
even though the ignitor glows it doesn't mean it's good,it works by amps. it takes 3.2 amps from the ignitor to open the gas valve,part number for ignitor is 5303935066 and it's around 65 dollars.you can look it up on the sears site http://www.searspartsdirect.com/partsdirect/part-model/Tappan-Parts/Range-Parts/Model-TGF320DWB/1269/0124002/R0510098/00002?blt=06&prst=&shdMod=
Posted on Oct 12, 2011
Finding the flame pilot on a caloric prestige series gas stove
There is no pilot. The igniter is in the oven cavity under the floorpan. This is a picture of the regulator and gas valve- the wire nuts at the top of the pic just left of center are on the leads that go to the igniter...
Jun 26, 2016 | Kitchen Ranges
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
Need help opening an older Caloric Prestige Series Range top
Generally you just need to place a flat blade screw driver in the crack about 3 inched below stove top and pry up, this exposes the entire under pan of the stove top.
Apr 07, 2014 | Stoves Kitchen Ranges
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Need owners manual for Caloric prestige series electric stove. self cleaning instructions
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
My caloric heritage series stove oven will not ignite.. pilot flame is on. I need parts..w here can i get them thanks.
I have a caloric prestige electric stove and the electronic ignition don't work. Does anyone have a solution for this problem?
Oct 05, 2009 | Stoves Ovens
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
