Question about Garden
Craftsman pressure washer 580.750901
Trying to get the chemical to mix with the water. Wont draw chemical in tube. Do I need to use the black tip in the wand since its considered low pressure?
5 Suggested Answers
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
LandaNW
  • 45 Answers
SOURCE: Craftsman Pressure Washer 580.752160
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Posted on Mar 10, 2011
Testimonial: "I had already disassenbeled & cleaned the spring/ball bearing. I found that, by removing the wand I freed up the restriction."
How can I get the soap to draw into the stream?
You need to use your black chemical tip if you have a switchable tip system on your wand...if your tip is the big plastic variable nozzle type, it pushes either in or out for low pressure chemical application...also, if you have the variable nozzle...go to a service center and replace it with a Quick disconnect and the switchable tip system...those varinozzles are bad for going bad and not working...Good luck
Sep 28, 2014 | Honda Garden
Honda lifter
I assume you are talking about the chemical intake tube... Most commonly you would see one end of the tube attached to the small tapered nozzle on the pump, and the other end which should have a small filter attached to it - is what you would submerge in a container of soap/degreaser/chemical solution of your choice.
If you have it set up in this way you will get the addition of whatever soap product you have the clear tube sitting in mixed into your spray stream. -- it's important to note that you will only get suction and soap flowing through if you are using the widest (black) spray tip. With the broad spray tip on you can get soap flowing either with or without the engine running - which can sometimes be helpful if you have to be careful of what you get the soap on.
Mar 21, 2014 | Honda Garden
Chemical wont siphon
In most cases this is because you have a high pressure tip, the red, white, yellow or green tip, on the wand. The detergent system will only work if you have the black, soap tip on the wand. With a pressure tip on the wand, there is too much back pressure for the syphon system to work. If you are using the soap tip, check the feed tube for the detergent for blockage, especially at the pickup filter and where it attaches to the water line.
Sep 16, 2012 | Powerboss 020309 3000 psi 2.5...
Diagram of a craftsman power washer
The only filter on the detergent pickup is usually at the end of the hose you drop into the detergent. To clean the line and syphon attachment only requires a little pressurized air to blow out any debris that may be in the line. Make sure you are using the black, soap tip on the pressure gun when trying to use the detergent syphon system. If you are using any of the high pressure tips there will be too much back pressure in the line for the syphon to work.
Aug 30, 2012 | Craftsman 2500 PSI Briggs & Stratton...
The chemical injection system on my craftsman 2500psi washer will not inject cleaner through the wand. have cleaned all parts and still won't work
The chemical injection system works by siphon action. You must have the black or largest/ low pressure tip installed for it to work properly. If you feel any pressure at the wand, most likely will not work. If your wand has the adjustable type tip, it may have a restriction causing pressure and not allowing siphon action. If you continue having trouble with siphon, you could plug/shut of siphon and install an aftermarket injector between the wand and the pump (not expensive). Sold at www.pwmall.com Good luck
Jul 01, 2011 | Karcher 2500 PSI Pressure Washer
HI. My Comet FWS 4030 works just great and i am very pleased. what i DON'T know is how to draw up soap to mix with the water. there is a big red knob, and another brass adjustment but i have no manual...
The red knob is to regulate the pressure. The soap siphon should be hooked up to the pump at the high pressure outlet and the pressure hose hooks up to it. You do just have to drop the tube into your soap solution but I recommend you dilute the soap down as the siphon usually sucks the solution up fairly fast. The trick to making it work is to use the low pressure, soap tip on your wand. They are black and help fan the water/soap out but give no resistance to the water coming out. If you are using a high pressure tip, usually red, yellow, white or green, there will be too much back pressure in the hose and siphon attachment for it to **** up any solution.
May 18, 2011 | Comet GXD2527G Pressure Washer Pump
My Karcher 2400 Pressure Washer will not syphon cleaning fluid. I have a reconditioned machine and the syphon for cleaning fluid has not worked for a while.Everything looks clean but still does not work'...
The black tip nozzle puts the right amount of pressure on the line to draw up the cleaning solution.
If your power washer is like mine, the cleaning fluid adapter is a 'T shaped' brass valve that fits in-line along the hose line.
There is a brass stem sticking out.
The stem has a tiny ball valve on the end.
A plastic hose fits onto the stem, and the plastic hose goes into bucket of cleaner.
As water travels through power washer hose, it creates suction that draws cleaning solution through the tiny ball valve.
The brass ball valve gets clogged or wears out ... we used to replace the stem every so often.
Sherwin Williams used to carry a replacement stem ... but they may not sell little parts any more.
It's been 14 years since I used the suction device.
I got fed up with the thing not working.
We changed over to a pump-up hand-held sprayer for applying cleaning chemical.
The pump-up puts more chemical on the spots where you need it.
So one guy puts chemical on, and second guy comes behind with power washer ... no more replacement parts, and one tip stays in the gun so we never lose a tip.
A pump-up sprayer is half the cost of replacing the T-shaped valve.
Duh-simple is the business model.
Nov 17, 2010 | Karcher Garden
Pressure washer will not draw soap from cleaning tank
I had similiar problem, be sure the detergent hose isn't clogged. Mine was clogged where the clear detergent hose entered the pump. I cleared the clog and it worked perfectly
Apr 04, 2009 | Garden
Mar 18, 2009 | Honda Garden
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Garden Logo
347 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
