Question about Garden
Fuel ratio on the weed eater 1400 Gas trimmer
2 Suggested Answers
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    What is gas to oil mix ratio on weedeater string trimmer
    The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
    Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    What is the oil ratio for the poulon pro link weed eater
    Hi brochon
    Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
    Please take time to rate me
    Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
    I found the manual for this model weed eater, according to the manual the mixture...
    and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
    must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
    mixed at a Ratio of 40:1 ...."
    and I quote once more from the manual "Helpful Tip. To obtain
    correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
    Hope that helps,
    If you like I can send the manual via email if you need it.
    :) happy weed thrashing
    Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    What is the gas to oil ratio for weed eaters?
    Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
    Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
    I hope this helps.
    Jul 16, 2011 | Homelite Garden
    What ratio of oil and gas do I mix together? How do you start it? I bought the weed eater used.
    If you bought it used, you can bet that they didn't run it out of fuel before they stored it, so the gas evapoated out of the carb and all that was left was oil, so mix your fuel 8 to one eight parts gas and one part oil, you'll have to hit the primer botton several times.
    Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    What is the oil to gas ratio for the husqvarna 125l weed eater
    Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
    Hope this helps,
    Chip
    Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
    Weed eater TE475 - fuel ratio
    FUELING ENGINE
    WARNING:
    Remove fuel cap slowly
    when refueling.
    HELPFUL TIP
    To obtain the correct oilmix
    ratio, pour 3.2 ounces of
    2--cycle synthetic oil into
    gasoline. Before operation, gasoline must be
    air-cooled engine oil designed to be mixed at a
    ratio of 40:1. Poulan/Weed Eater brand
    synthetic oil is recommended.Mix gasoline and
    oil at a ratio of 40:1. A 40:1 ratio is obtained by
    mixing 3.2 ounces (95ml) of oil with 1 gallon (4
    liters) of unleaded gasoline. DO NOT USE
    automotive oil or marine oil.
    Jul 05, 2009 | Yard Machines Garden
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
